Old 07-30-2012, 07:12 PM
almagg almagg is offline
sealed vs 'cap topped' batteries
97 buick skylark v6
the first battery i put in was a sealed self-maintenance ac delco with the hydrometer green light on top (lasted 5.5/7 yrs).
and it looked something like this:
http://sealedperformance.com.au/sealed_maintenance.php
after that the 1st used battery lasted about 4 yrs. i am now on the 2nd, from Advance' about 3 yrs. since i just put in a brand new alternator (not rebuilt) i want to get a new battery.
i don't think the first kind is around anymore but there is a place i am going to check tomorrow.
anyways currently this is what i found:
(2nd from bottom - 75PG)
http://www.bennettauto.com/ShopByVeh...key=_3K80NM7IA
i can get it for $90 but at the store when i
saw the caps on top i figured i should do some more checking.
anyways i read that they are getting away from completely sealed 'wet' batteries.
thanks for any input.
i.e., go with the 'capped top'. delco?
Old 07-31-2012, 09:50 AM
Re: sealed vs 'cap topped' batteries
never mind.
went with the 75PG.
found out same as the 75-7yr i had previously.
different warranty.
Old 07-31-2012, 10:49 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If you want maintenance-free, then get the sealed type from a good brand: Sears Die Hard, Interstate, even Wal-Mart EverStart have good reps. Good warranties are also important as you already know...the longer the better, especially the free replacement period.
I personally think I can keep tabs on the general maintenance since I do it myself, so I opt for the type with caps. They are generally cheaper, and the warranties almost as good as the sealed types. All you need for maintenance is a turkey baster, a jug of distilled water, and maybe a battery checker (to test the electrolyte for specific gravity).
So if you're a do-it-yourselfer, cap types are easy enough. But for the hands-off driver, opt for a maintenance free battery.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
