Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 07-30-2012, 06:50 PM
olympian2012 olympian2012 is offline
2011 Avalon blinking light
I've noticed whenever I put into Reverse, the lighted box around the R blinks. dealer can't figure out why this is happening. Any one heard of it before?
Old 07-30-2012, 09:54 PM
Joe W Joe W is offline
Re: 2011 Avalon blinking light
This is likely an electrical issue between the computer, reverse switch, and the rear lights. are there any other dash lights on?
Old 07-31-2012, 08:13 AM
Joe W
Thank you for the reply to the lighted square around the R.
The asnswer to your question is that no other lights are on. The backup lights and the break lights all work as do the turn signals. TX for the reply
Old 07-31-2012, 11:32 PM
Given your info I would lean toward a wiring issue as the suspect lights are all working... and there are no codes. Check pinch points in the wiring that may cause a possible short. For this evaluation you want to work backwards in the wiring from the reverse lights looking for possible grounded wires allowing the lights to work but still triggering the faulty R light.
Old 08-01-2012, 09:23 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Look at the wiring loom in the trunk near the hinges. This is a notorious trouble spot.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-01-2012, 07:06 PM
Joe W & Brian R.:
Thanks to both of you for the answers and the help on this vexing problem. I will check the trunk and inform the "experts" at the local dealership about the possible problem spots.
TX to both
Olypian2012
Old 08-01-2012, 10:32 PM
Thanks Brian, I was uncertain if this issue extended to the 11's
Old 08-02-2012, 11:31 PM
Brian R.'s Avatar
Resident Chemist
I'm not sure either, but it is an obvious weak point in Toyotas, historically - and similar symptoms have been found for this problem.
Old 08-03-2012, 07:14 AM
Jeff Collision Jeff Collision is offline
Toyota provided lights for "cold engine" and "hot engine." When in reverse a box blink around the "R" of the gear indicator.
Old 08-05-2012, 01:08 AM
Jeff, could you please expand on this???
