Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-30-2012, 03:36 PM
Shore_Fisher Shore_Fisher is offline
2001 Rodeo: Front End Overhaul - Tips?
Partway through a front end overhaul of my 175k 2001 3.2L Rodeo 4WD, brought on by the need for new brakes, new front drive shaft CV's and realignment.
I would appreciate any tips from experienced members on the following:
  1. I can't see why I need to remove the steering rack and the SOTF system to get the front axle and driveshafts out (Obviously need to disconnect vacuum and electrical lines from SOTF). Am I missing something?
  2. Do the front ABS sensors just pull out towards the engine once the two Torx screws are removed? Can I spray them with WD40 to clean/loosen, then clean up with brake cleaner?
  3. Should I change the front ABS sensors while I have everything apart? (Had very infrequent ABS light for years)
  4. Should I change the control arm bushings while I am there?
  5. Should I replace the wheel bearings/races, or just repack them if they seem OK?
  6. Anything else I should be doing while I have the front end apart to this level?
Thaks in advance!
Ed
Old 08-01-2012, 10:14 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2001 Rodeo: Front End Overhaul - Tips?
try posting this at: planetisuzoo.com
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Tags
2001 , abs , end , front , rodeo
