Old 07-30-2012, 03:27 PM
MIKEVINN2007 MIKEVINN2007 is offline
2000 S-10 No Reverse
2000 S-10 has no reverse. I can hear a whirling sound when switching between reverse and neutral and similar when I shift to drive from reverse and back to neutral then reverse i hear the sound slow down and pic up as i shift. the trans was replaced aout two years ago at a tramsmission shop but is now out of warrenty.
I suspect torqe converter may be bad or that may be where the sound is coming from that I hear.
It seems like when i shift to reverse that i feel a faint slight twist of the drive shaft like it might start to go into reverse but then nothing.
Any sugestions?
Thanks
Mike
Old 07-30-2012, 07:16 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 S-10 No Reverse
Any sugestions?
Thanks
Mike
NO Reverse = pull it out and fix it or replace it.
MT
Old 07-30-2012, 09:51 PM
Blue Bowtie's Avatar
Registered Offender
Is it shifting through ALL the forward ranges normally, without noises?
Old 07-30-2012, 10:31 PM
Joe W Joe W is offline
This is never good. Many times reverse is the first to go. Don't take it to the same shop if you are out of warrenty.
