Old 07-30-2012, 03:10 PM
JerryJerry JerryJerry is offline
2000 Windstar starts, then stops
My 2000 Windstar SEL will start perfectly, idle for 6-7 minutes, then choke off. It will restart, but won't run. After a few restarts, it won't start again unless the gas pedal is held to the floor. Then it starts, but chokes down and runs rough before shutting down. A few hours or days, and it will start just as I have described above. When it starts, I can run the air, radio, move it forward and reverse. If I try to drive it, it chokes down and stops.
Any assistance would be appreciated.
Old 07-30-2012, 07:59 PM
grog11 grog11 is offline
Re: 2000 Windstar starts, then stops
You may want to check the fuel pump pressure .Its probably weak and failing.
Old 07-30-2012, 08:33 PM
scubacat scubacat is offline
I was thinking that as well. How long has it been since you changed the fuel filter?
Old 07-31-2012, 04:16 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Fuel pressure too, but you might want to try and clean the IAC valve. My failing one can do some funny things when acting up...
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 07-31-2012, 04:50 PM
IAC is only for idle. Hitting the gas shuts that off so the air passes through the throttle. This is most likely a fuel pressure issue which is why I'd start with the fuel filter.
Old 07-31-2012, 05:06 PM
olopezm's Avatar
I know, but mine seems to stick from time to time causing the RPM's to surge after taking off from a stop. That's why I said mine makes funny things, it's very clean tho.
Oscar.
