Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-29-2012, 12:54 PM
Cabeto Cabeto is offline
Exclamation Help Needed
I have a 2000 Buick Century that I cannot get to start. While my wife was driving home it started to sputter (like running out of gas) and did a little back firing. She made it home and I put in some gas (Just to make sure) and the care cranks over but will not start. I have replaced the fuel filter, checked the spark plugs and replaced the CAM Sensor. The car still will not start. Anyone with this experience that could give some much needed advice?
Old 07-29-2012, 10:11 PM
Tech II Tech II is offline
Re: Help Needed
Spark on all cylinders?
Check fuel pressure?
Will it start if you spray carb cleaner into the intake?
Old 07-30-2012, 09:54 AM
Re: Help Needed
Yes there is spark and it will start if you use carb cleaner but will not stay on and backfires. I will be checking the fuel pressure next. do oyou think maybe timing chain or fuel pump?
Old 07-30-2012, 04:13 PM
Re: Help Needed
Check fuel pressure with a gage...
Disconnect the fuel injector harness and spray carb cleaner into intake....if it runs as long as you spray, then it's a fuel delivery problem....if it backfires, do a compression check....
You have spark on ALL cylinders? If yes, how long those plugs been in there?
The Following User Says Thank You to Tech II For This Useful Post:
Cabeto (07-31-2012)
Old 06-29-2013, 09:40 AM
rmarotta rmarotta is offline
Re: Help Needed
crankshaft position sensor.......
Old 06-30-2013, 09:17 AM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: Help Needed
Welcome to AF. 2 comments here, this is an old inactive thread, also the cps would not be the issue as the car had spark, which eliminates the cps as an issue.
