Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 07-28-2012, 06:33 PM
tkswan's Avatar
tkswan tkswan is offline
transmission concern
2002 LS V8 162K Miles.
Its been sitting in the garage for 10 days. ...went on vacation. Started her up and let it idle down. Shifted to reverse and transmission shift error displayed. Went back to P. Waited a minute. Shifted again and she was hard jumping into the gears. The error went away. Drove it around and it seems to shift fine. Opinions?
-tswan
Old 07-28-2012, 11:30 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: transmission concern
I'd just keep driving and see if it acts up again. If so, it's probably the valve body/shift solenoid issue that's covered in a TSB. You could also try starting with a fluid and filter change if it's been awhile since that has been performed.
-Rod
Old 07-29-2012, 11:27 AM
tkswan's Avatar
-Rod
Ok i'll do the fluid filter this week. Can you point me to that TSB you mentioned? I would like to read it.
Thanks
-tswan
Old 07-30-2012, 06:32 AM
shorod's Avatar
SHO No Mo
Here's a teaser for the related TSB. If you'd like the full text, send me a Private Message with the request and an e-mail address and I'll send you a PDF of the full TSB. I see this only lists the 2004-2005 LS. I thought there was a similar TSB for the earlier LS but if so, I don't appear to have a copy of it.
-Rod
TSB 05-21-8
10/31/05
DELAYED OR HARSH REVERSE ENGAGEMENTS - 5R555 TRANSMISSION - VEHICLES BUILT PRIOR TO 09/23/2004
FORD:
2004-2005 Thunderbird, Explorer
LINCOLN:
2004-2005 LS, Aviator
MERCURY:
2004-2005 Mountaineer
This article supersedes TSB 05-15-4 to correct the Service Procedure.
Old 08-03-2012, 03:07 PM
tkswan's Avatar
had the transmission flushed. what a difference new fluid makes. it shifts nice and smooth again, and that light thump when shifting from 2 to 3 is gone too.
-tswan
