Old 07-27-2012, 05:41 PM
laxman21's Avatar
laxman21 laxman21 is offline
ignition signal indicator
Need a 12v source for this and I was going to use an add a fuse for it. Just want to know what is a good fuse to use under the hood
Thanks
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-02-2012, 09:09 AM
j cAT j cAT is offline
Re: ignition signal indicator
Thanks
pick a fuse with a large amperage. place your fuse that takes power from this as close as possible to the supply fuse. how much is the fuse your installing for this ? if less than a few amps ok. if more best find ignition source feed wire and mount the fuse there.
