Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 07-26-2012, 05:10 PM
mcooke1996 mcooke1996 is offline
96 Firebird starting problem
I have a 1996 Firebird, and I'm having issures with the car starting. At first this happend once in a while and I could pump the gass a few time while cranking the car and it would start. Now its happening more frequently and my father and I can't seem to figure out whats causing it to not start. We change the fuel filter, I think my dad changed the ignition cluch. The car gets fuel, and it gets a spark. On the bad times when my car just sits there and cranks, I have to pump the heack out of my gass in order to start the car. One time it wouldn't start, even with me pumping the gas and I killed my battery. I was wondering if anyone had an idea on what could cause this to happen.
Old 07-26-2012, 07:53 PM
Tech II Tech II is offline
Re: 96 Firebird starting problem
Which engine?
Check for codes?
Will it start with carb cleaner sprayed into the intake?
Was a fuel pressure reading taken?
Spark on ALL cylinders?
Old 07-26-2012, 08:51 PM
I haven't done any code reading or fuel pressure reading. I have no check engine light on eather. The spark plugs are almost new. They might be 2 months old.
O and its a T1 engine
Old 07-26-2012, 08:52 PM
Do you have any recamendations on where I should take it to get the codes read and fuel pressure checked?
