Go Back   Automotive Forums Car Chat > Pontiac > Vibe > General Discussion
Old 07-26-2012, 12:37 PM
housecluff housecluff is offline
led strip lighting
Hello everyone. I was wondering if it would be possible to install led strip lighting that would turn on when the dome light comes on. Could I splice the wiring to the dome lights and tap into them? I'd like them to come on automatically when the doors open so that I wouldn't need a switch. The car is a 2003 Pontiac vibe gt. Any help would be appreciated.
Old 07-26-2012, 07:24 PM
Tech II Tech II is offline
Re: led strip lighting
Depends on the current load of the led's.....is the wiring of the circuit large enough to handle the added current, as well as the fuse? As a general rule, led's don't draw too much current, but you don't say how many are added to the circuit.....
Old 07-26-2012, 08:07 PM
danielsatur danielsatur is offline
Need to find the best place to tap in the circuit for dome light, you might even consider using a LED dome light too. www.alldata.com
Old 07-26-2012, 11:41 PM
Thanks for your response! I would like to add about 8 feet, 4 feet on each interior side of the car, but there are only two dome lights to tap into. Would replacing the halogen bulb with an led, like danielsature suggests, reduce the load enough to carry that amount of leds? What do you think the limitations would be as far as how many feet of leds the circuit could handle?
Old 07-27-2012, 10:32 AM
Power (P)= Voltage(E) X current (I)
P=E X I
Voltage (E) = Current (I) X resistance (R)
E=I X R
12volts
How many amp Fuse ?
Traditional Dome uses how many watts?
How many watts per foot?
How many leds are being used total?
Also see www.tmart.com for home/auto LEDS.
Old 10-12-2012, 06:04 AM
daza daza is offline
Did you do this in the end?
Strip Lights
Old 01-24-2013, 02:00 PM
autobahn13 autobahn13 is offline
I bought led strips from a website called LizardLeds, and they sell wireless remote dimmer switches with them so you could turn the lights on with the remote while walking to your car, much easier in my opinion.
