Old 07-26-2012, 12:42 AM
red39715 red39715 is offline
95 Metro no power
The car starts fine. It sometimes takes a few seconds of turning the car over to get it started. I guess I should state that it is a 3cyl 5 speed. When you go to drive it there is no power. A hill I use to go up in 4th gear I now have to use 2nd gear. I have replaced the plug wires and it operates the same. If I take off each wire while it is running you can tell that cylinder was working. I have not checked the compression yet. I am thinking it might be the fuel pump. I'm going to also check the fuel pressure. Any other ideas out there?
Old 07-26-2012, 05:14 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: 95 Metro no power
It's worn out, check your compression. Engine warm, all plugs out, throttle wide open. Factory is 200 psi, recommended minimum is 150 psi. Usually when they get hard to start, they're down around 120.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 07-26-2012, 08:18 AM
Jeff Collision Jeff Collision is offline
As you said, check your compression and fuel pressure. In addition, check your fuel filter. If you have clogged sound, replace the filter.
Old 07-26-2012, 12:14 PM
Metro Mighty Mouse's Avatar
Metro Mighty Mouse Metro Mighty Mouse is offline
Might be a clogged catalytic converter as well. Easy way to check it is to loosen the exhaust where the cat bolts in and put something between the flanges to hold it open. It'll be loud but if your power returns then the cat was the issue.
Old 07-26-2012, 11:00 PM
Rebuilt the engine less then 5000 miles ago. Removed the Cat also.
Old 07-26-2012, 11:13 PM
danielsatur danielsatur is offline
Is the HP lost at the front wheels?
It could be as simple as a bad clutch.
Old 10-02-2013, 04:59 PM
tsc73 tsc73 is offline
Check the fuel filter also the fuel pressure regulator. The pressure regulator is an easy fix and its one of the top 3 problems of the 92 metro. The regulator only costs between $30-$40 . Just know it doesn't come with the spring. So clean the spring with a rust remover sold near the fuel treatment section of your auto store.
