Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-24-2012, 01:58 PM
gen6eric gen6eric is offline
TPMS Rebuild Kit
I need to replace the OEM tires on my 2007 Camry (22,000) miles and Discount Tire is pushing $10 each TPMS Rebuild Kits. They insist that without the rebuild kit that the tires will be at risk of leaking.
What is the general consensus on the need for replacement "parts" in this situation?
2001 Alero (V6 3.4L VIN E)
1999 Malibu (V6 3.1L VIN M)
Old 07-25-2012, 08:38 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: TPMS Rebuild Kit
I'd be curious to ask what is in their rebuild kit that costs so much. In general, when any tire is replaced after normal wear, the valve stem is replaced, too. Otherwise, the rubber o-ring that seals it against the rim can get old and brittle, causing an air leak like they suggest.
Now, with TPMS, you can't just toss the old stem because it is attached to the pressure transponder. But you can replace that seal and the valve core, which by my guessing would cost about $5. If they also add the washers and nuts, maybe $10 is reasonable cost for the convenience.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
