Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-22-2012, 11:44 PM
mastertechbmuss's Avatar
mastertechbmuss mastertechbmuss is offline
engine making ticking noise
my mom has a 2003 pontiac montana thats making a ticking noise says its low on oil but i just changed the oil 2 and half weeks ago i just need help trying to figure out why it would be ticking
Old 07-23-2012, 11:04 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: engine making ticking noise
Have you checked the oil level? Did it make this noise before the oil change?
Old 08-02-2012, 10:03 PM
JabbaTHutt JabbaTHutt is offline
I didn't know they had an oil level indicator
2003 Montana EXT
Most options
Niagara Falls
Canada
Old 08-04-2012, 08:30 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Ticking from an engine can be related to many issues. First I suspect a lifter. Lifters can tick for many miles with no adverse affects on the engine. If you changed the oil recently the I would make sure the oil level is good. Use the dipstick to determine if you have the right amount of oil, make sure the van is level when checking it. I also am assuming that you changed the oil filter as well. If not then you may be suffering from an oil issue related to a blocked or partially blocked filter. Also did you use the proper weight of oil specified in the owners manual. An oil that is too thick can cause ticking issues in an engine.
I hope this helps!
