Old 07-22-2012, 06:02 PM
accord02 accord02 is offline
Car won't start everytime I pump gas, Please help!!!
I have an 02 accord SE. The last few times that I have pumped gas the engine would not start until 10 minutes later. First time I turned the key in the ignition there would be no sound, I tried again 2 minutes later and there would be a little sound, next time I tried there would be a little rumble. I'd wait and try 10 min later and it would start again... It has happened the last 3 times I've pumped gas and only when I pump... can someone tell me what is wrong?? Thanks in advance.
Old 09-03-2012, 05:24 PM
Jessefjr Jessefjr is offline
Re: Car won't start everytime I pump gas, Please help!!!
Hey I'm not sure if you fixed your problem or not but my wifes 93 accord was doing the same thing. I had her to leave the car running when she would gas up and that worked for a little while but it started doing the same thing with just a regular grocery stop on the way home from work. Finally took it to a local shop and it was a relay under the dash on the driverside. I cain't remember the name of it though. It's been about a month now with no problems. Hope this helps.
