Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-22-2012, 03:23 PM
trox trox is offline
96 civic no spark, no start
I ran through a ditch, hit culvert full of rocks. Both airbags blew, hole in transmission and oil pan. Engine shut down on its own. I think? looked under the hood, to look at damage, didn't see any of the holes. Tried to start it, it turned over, but didn't start? Since then I have replaced the Transmission, and the Oil pan, and airbags. Now it turns over, but no spark, Is there a inertia switch that needs to be reset? Does the Airbag computer need to be reset?
Old 07-24-2012, 07:19 AM
Re: 96 civic no spark, no start
Never mind guys, I got the answer from a Honda forum. The Fuel Pump/ SRS fuse was blown. I guess the SRS side was preventing ignition because it worked after changing the blown fuse. This fuse also prevented an O'Reilies Diagnostic tester from communicating so, if your dead in the water, no spark, no fuel, SRS light on, check fuse 13 (Fuel Pump/SRS)
