Old 07-22-2012, 12:05 PM
northern piper's Avatar
northern piper northern piper is offline
chirp from front wheel bearing?
Just came back after driving my wife's 2000 windstar 3.8. I haven't driven if for a while and it sounds like the driver's front wheel bearing is on it's way out. It doesn't make the classic whirr or marbles in a tin can sound but more so a chirp sound. Definitely increased and decreases with speed, isn't a rotor or belt problem.
Has anyone experienced a chirping bearing?
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 07-22-2012, 12:52 PM
12Ounce 12Ounce is offline
Re: chirp from front wheel bearing?
I've experienced a chirping cam position sensor synchronizer. It can eventually shut down the engine.
Old 07-22-2012, 02:17 PM
I wondered about that but wouldn't a cam position sensor chirp when the motor is running but vehicle is in park? This chirping only happens while driving and increases/decreases with speed, but not when running at while stopped at an idle.
I'm just kinda thinking the typical metallic ball crunching in the can sound hasn't started yet...
2000 windstar 3.8
Muskoka Canada
Old 07-22-2012, 05:53 PM
Yes, your analysis is correct ... I wasn't sure from your earlier description. Of course, brake systems can offer such noises ... but the bearing is a good candidate. Does the noise change if you are turning left or right?
Old 07-22-2012, 08:28 PM
so I put the van up and did the 12 o'clock - 6 o'clock push pull test and everything seems solid. The 9-3 also is good and as I did the lca's, inner/outer tie rods, quick struts, brakes not too long ago I know they're pretty solid. It definitely isn't chirping from any belt, idler or cam position sensor. So, I go out for a drive, and low and behold, the noise is completely gone... wtf? Oh, there was a slight difference when turning left when it happened earlier but again... no sounds now at all so I can't really say I've done an exhaustive review.
Anyway, I'm going to monitor it and get my 10 yr old son to monitor it.. (he's the only 1 out of the 4 regular riders in the van that notices anything mechanical... don't ask about the gender of the other 3 )
I'm still thinking it was bearing but if I don't have to do it right now that'd be great.
the saga continues ..
2000 windstar 3.8
Muskoka Canada
Old 07-23-2012, 07:49 AM
I haven't done one yet on my '99 ... but I understand these are the new style cartridge bearings, similar to ones I have done on the Escape ... not too bad to deal with. Not like the old days.
The Following User Says Thank You to 12Ounce For This Useful Post:
carrfixr (09-04-2012)
Old 07-23-2012, 07:59 AM
ya, they're a bolt off, bolt on type repair. Assuming you've got the hub nut socket and a big breaker bar you're good to go.
I'm kinda happy that the noise is gone (for how long??) as I've got a half built 6 x 10 utility trailer on my lift that hasn't got the axle welded in. Had I needed to do the hub, the first step is weld on the suspension for the trailer, install axle, remove from lift.. then start the hub... a lotta work at the end of a long hot day at my "real" job
2000 windstar 3.8
Muskoka Canada
Old 07-23-2012, 05:05 PM
Windstartled Windstartled is offline
Exclamation Re: chirp from front wheel bearing?
Those bearings are very easy to replace on the rear wheels especially those with drum brakes but the front wheels is a whole different story. For some reason Ford had the genius idea of positioning one of the three fastening bolts at a spot where access is completely blocked by the steering knuckle so you have to remove the knuckle and everything attached to it: caliper, strut, the whole shebang. So it's worth making sure the bearing is really bad before spending a whole day doing this especially in this blistering heat. One life-saving tool for this job is a three-prong gear puller aka "spider" otherwise the old bearing will hang on with a death grip that even a mini-sledge won't budge. Spider costs about $30 and worth every penny. Pulls out rusted wheels as well, not always an easy task with a hammer especially in winter.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
Old 07-23-2012, 07:12 PM
scubacat scubacat is offline
This really sounds like squeaky brakes to me and not the wheel bearing. Next time you hear the noise, see if turning the wheels to the right and then to the left changes the noise at all.
Bearing noise, in my (albeit limited) experience, sounds more like a loud washing machine spin cycle as it speeds up and slows down.
Old 07-23-2012, 09:13 PM
Mine sounded like a friggin' prop plane lol
Old 07-24-2012, 08:25 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Hi northern,
some time ago, mine did the same; the funny thing is that it started making the sound weeks AFTER replacing one bad wheel bearing. This was done at a shop and I was so angry...
I inspected it myself and wheels were tight, everything else was too, and the noise stopped after that and never came back! Just like yours...
I don't know what happened, maybe the lug nuts weren't properly tightened or who knows. From that day I keep special attention to any single noise any of my rides makes; I think I'm being overly paranoid, but with all the things that have happened to my family and me, I don't want to risk it.
If it ever happens again and I find the cause, I'll let you know...
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 07-24-2012, 09:04 PM
thanks for that Oscar. I'm with you on the listen to every little noise tho... I've had too many things happen over the years to just shrug them off..
I'm kind of thinking that the cheep/chirp sound I heard might have been a stone caught in the tire tread .. anyway, I'll keep my eyes and ears open as they say!
2000 windstar 3.8
Muskoka Canada
Old 07-30-2012, 07:50 AM
well, the chirp is back and it's definitely something rubber. This time when I heard it the temp was higher than before (is that possible this summer???) and it's got that rubber rubbing on something sound. I'm going to put the van on my lift tonight and take a peak. I think it's safe to say it isn't the hub bearings, I'm thinking maybe cv boot or something along those lines...stay tuned!
2000 windstar 3.8
Muskoka Canada
Old 07-30-2012, 09:55 PM
Rubber expands in the heat does it not? Lots of rubber parts must be in a permanent state of expansion this summer then
With regards to vehicle noises while driving I find it useful to drive along quiet narrow streets with windows down and radio off and listen to my van's sounds as it is reverberated off buildings and parked cars. For high speed diagnosis I use a portion of highway that's under construction, the lanes are only 12 feet wide because they are separated by "walls" made from 36-inch tall concrete blocks that stretches for about a quarter mile I would say. I can clearly hear even faint sounds emanating from the van as it cruises down the 'tunnel'.
Old 07-30-2012, 10:32 PM
kevink1955 kevink1955 is offline
When the wheel bearing on my 96 went the clue was a chirping noise, I put the front end up in the air and pulled the wheels. I put the lug nuts back on to hold the rotors and ran the engine at idle.
I found the Pass side rotor and hub were not running true and as a result the brake caliper was rocking back and forth on the slides, thats where the chirp was coming from.
When I replaced the bearing it was realy bad, could hardly turn it by hand and it was rough when it did turn.
On the 96 the bearing is pressed into the kunckle and the hub, not a fun job at all, I think the 2000 has a 3 bolt cartridge bearing, much easyer to change.
