Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-21-2012, 04:03 PM
CarlosG7430 CarlosG7430 is offline
1998 Chevy Suburban ac problems
Rear AC not blowing air
Old 07-21-2012, 07:13 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 1998 Chevy Suburban ac problems
So...the fan does not work? Or does it not blown cold air? If the fan works, you need to check the a/c pressures. Low charge will cause this.
Old 07-21-2012, 07:40 PM
I tested the fan directly & it does work, i replaced the relay & it still doesn't work, i check the power but there is no power going to the fan so i checked the ac switch & there is power going to the switch, i really don't know what else to replace
Old 07-21-2012, 08:26 PM
j cAT j cAT is offline
since you applied 12volts to the blower motor and it works also the blower when hooked up normally does not work in any position I would re check all fuses. check for power to those fuses as well.
Old 07-23-2012, 11:17 AM
jtmarten jtmarten is offline
Does the rear blower work for heat?
Shouldn't there be a separate pressure switch for the rear system? If the refrigerant is low, you may not have enough pressure to fire up the rear system.
2005 Saab 93 Aero
1996 GMC K2500 Sub w/conversion pkg
1964 Ford Falcon 'vert
1980 Bradley GT2 96v Electric
1978 GMC Royale Motorhome
1978 Glastron/Carlson CV23; 460/Berk JE jet
Old 07-23-2012, 03:08 PM
No the heater doesn't work either i changed the porportion value but nothing only thing i need to replace is the ac switch
Old 07-23-2012, 04:00 PM
If the rear blower doesn't work for heat either, it has nothing to do with the AC pressure switch. Sounds like one of the fan switches, or diode pack if separate, is bad.
2005 Saab 93 Aero
Old 08-07-2012, 05:42 PM
Alice Alice is offline
I have a 95, might be the same. I dont even turn the ac on anymore. It quit blowing in the rear like dust and crap was stopping the right vents from opening up. Then someone else told me it's some hell getting to that stuff, so I forgot about it. Had already switched from some old coolant to some new ac coolant, they put something in the lines. Cost me more to recharge the system the very next year, cuz thats what they said would fix that no blowing cold in the back. None of that worked, old bastard truck likes to blow the odd belt, Alt gauge is whacky. Running a 6.5L diesel, runs hot as it is, AC used to always just make it run hotter. I gave up. But search here for more info about those rear vents, there is a good chance I read it here.
