Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-20-2012, 08:54 AM
dorlow dorlow is offline
Keyfob remote only works if I'm next to my car?
I have a 2004 Impala with 140,000 miles on it. I've owned it since brand new. I noticed the last few weeks, I need to stand right next to my car to lock or unlock the doors with the keyfob. When I first started noticing it, I though obviously it's the battery. The battery in the keyfob is now 8 years old or so. I bought a brand new battery and replaced it, but the problem didn't go away.
So, now I'm wondering is the keyfob itself bad? Or is it common for this problem to be caused by something else?
You know, I just got to thinking, recently I bought a new FM modulator for my iphone and it's interfered with my GPS (built in the iphone) and cellular in the iphone. After monkeying around with the fm modulator for a day or so trying different frequencies, I found one that didn't interfere with all that stuff. I wonder if that being on all the time is somehow near the frequency of the door locks... I just thought of that at this moment. I'll have to check that.
But does anyone else have any other ideas?
Old 07-20-2012, 10:26 AM
danielsatur danielsatur is offline
Re: Keyfob remote only works if I'm next to my car?
Consider buying a new Key fob from Ebay.
Old 07-20-2012, 11:21 AM
Forget it, I answered my own question. It is the FM Modulator causing the interference making my keyfob not work. I just unplugged it and I am able to walk quite far from my car and it works fine.
It's amazing the last FM modulator I used I just randomly picked a channel and everything worked no problem. With this one, it seems like no matter what channel I pick, it interferes with something.
I don't know if I'm willing to go back though. The last one was a generic FM modulator that just used a miniplug to feed from my iphone. This new one mounts the iphone and plugs in through the dock connector and feeds the audio at line level and sounds so much nicer. But the interference is getting annoying. I guess I haven't tried every channel. I'll just have to keep tinkering with it.
Old 07-24-2012, 12:12 PM
rkvons's Avatar
rkvons rkvons is offline
Why don't you have your modulator controlled by your ignition so that when you remove your key, it powers down?
Old 07-24-2012, 01:52 PM
Where do you get something like that? I've heard of cars that the cig lighter turns off when the key is off. So, if I had one like that, then when I turned off the car, the modulator would turn off.
Old 07-26-2012, 12:33 PM
rkvons's Avatar
I think it would require some investigation in your dashboard area. Your radio, for instance, is controlled by your ignition. You would have to pull it out and locate the power to it, and tap into that.
Old 07-26-2012, 08:34 PM
One cigar lighter is a hot 12volts all the time, the other 12volt socket works with the ignition key.
Try looking for the other cigar lighter socket.
Old 08-03-2012, 07:22 PM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Re: Keyfob remote only works if I'm next to my car?
since the cigarette lighter is hot and the aux power jack is hot also, you will need to unplug it when you leave the car. The key fob uses a radio signal to connect to the radio in the car or another module. The modulator caused second and third harmonic signals which disrupted the fob.
Good luck to you.
John
Happiness is driving a Chevrolet!
Old 11-01-2012, 09:51 PM
sourjacks sourjacks is offline
When having issues with remotes from a distance, it helps to touch the remote to the bottom of your chin while pressing a button. This seems to buy you a little distance. I get crazy looks when I tell people this, but I heard it somewhere a couple years ago and found that it works for me?!
