Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-19-2012, 11:18 AM
tidus21221 tidus21221 is offline
93 Rodeo 4x4 starting issue
93 Isuzu Rodeo LS V6 4x4 auto starting issue.
so truck was running fine when i bought it. I drove it an hour home with
no problems. I was jumping my car and my idiot brother put the jumper cables on wrong terminals. the truck was still running untill we turned it off then didnt start back up. So im already guessing battery fried, tested it it was bad so i replaced it. now it will turn over but wont start, found out my #6 ignition coil wasnt geting spark but #1 was, so i replaced ignition coil. now it sound's better but still wont start. i checked all the wires and they all have spark, im checking the plugs in a couple of hours, any ideas??... also was thinking of getting starter fluid for the intake to rule out a fuel problem. thanks an any help will be apreciated.
Old 07-19-2012, 12:53 PM
Re: 93 Rodeo 4x4 starting issue
couple of plugs were bad so i changed them all still no good... anyone?
Old 07-22-2012, 07:36 PM
tested all fuses and thier all good. rechecked everything on ignition side and im getting spark 4 sure, i even tested spark plug wires with ohm meter so their all good. now on the 1st try the truck starts goes up to 1000rpms then stalls right after i start it, but i cant get it to start againanyway i got a chilton manual and of course it says nothing about what i should do if the truck doesnt start. waist of $30 bucks, all my relays are good 2. still no ceL codes. can anyone help, truck just wont stay running.:c rying::cry ing: lolol
Old 07-22-2012, 09:22 PM
cleaning throttle body an iacv tomorrow ill post news after work
Old 07-27-2012, 01:58 PM
did iacv still no changed. sprayed starting fluid in the intake truck started right up. cant believe no one is replying to this post kinda sucks. anyway fuel pump primes, b4 i go to get a pressure gauge i unplugged the hose after the fuel pressure gauge and turned the truck over and no fuel squrted out, any ideas plz
Old 07-27-2012, 03:11 PM
chilton manual says 9-13psi for fuel pressure, it starts at 30psi then slowly drops every time the engine rotates. im not sure what could be bad or if this is bad. as thier seems to be more fuel pressure then the book says.
Old 07-27-2012, 05:08 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
93 isuzu rodeo 3.2 shows 25-30psi at idle with vacuum to regulator, 41-46psi no vacuum and should flow 1/4qt in 15sec
Old 07-29-2012, 10:46 PM
did the noid light an it was a steady flashes, do u want me to check every injector with the noid light cuz if one is pulsing doesnt it mean the ecu is good?
