Old 07-17-2012, 09:19 PM
Esondag Esondag is offline
94 Chevy K1500 Blazer
I want to take everything electronic out of my drivetrain in my Blazer. Currently in shop with the motor pulled with intake and carborater ordered. The guys at the shop said that it's a matter of pulling a plug on the automatic transmission to make it not run off the computer? Is that correct? What else do I need to do to take this truck off electronics???
Old 07-21-2012, 08:30 AM
Blue Bowtie's Avatar
Registered Offender
Re: 94 Chevy K1500 Blazer
In the '94 models, the transmission will require the PCM to shift gears. You could replace the trans with an older TH700-R4 set up for 4WD, but that might prove costly.
Old 07-21-2012, 01:17 PM
Tech II Tech II is offline
You are also going to have VCM and harness problems...
Old 08-29-2012, 10:48 PM
Thanks for the response guys. The motor is put together and waiting to put the headers on and exhaust. It looks like I'll be getting a call pretty soon about transmission replacement next. On the ignition will I have to go to points ignition to stay away from an electronic ignition?
