Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-17-2012, 07:46 PM
budguy007 budguy007 is offline
Question 2002 ram idling weird
I have 2002 Ram 4.7 Ltr, 105000 miles and at idle it revs high and then normal then high then normal. I have no idea what is the issue. Anyone have any ideas? I do think it might need a tuneup but not sure if that has any idea with the idle issue.
Old 07-18-2012, 05:23 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2002 ram idling weird
The idle air control valve (IAC) might be sticking and need cleaning with carburetor cleaner.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-20-2012, 01:28 AM
hundahunta hundahunta is offline
check the pcv 90 deg hose at the rear of the intake manifold may be split causing and vacuum leak
The Following User Says Thank You to hundahunta For This Useful Post:
KEVINP (09-06-2012)
