Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 07-17-2012, 03:37 PM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
Angry 02 neon 2.0
transmission question/issues, when the shift syloniod is hooked up and the transmission get warm it starts to slip but when the trans comp/syloniod is not hooked up it drives for the most part fine with the engine light on please some one help i need to get this thing fixed asap
Code:
:banghead:
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
Old 07-18-2012, 07:50 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 02 neon 2.0
What do you mean when the shift solenoid is hooked up?
2003 Dodge SRT-4
Old 07-18-2012, 01:46 PM
FORDGUY09's Avatar
Re: 02 neon 2.0
with the shift syloniod hooked up the and the transmission warm it slips with it un hooked and trans warm it drives normal like there are no issues with the transmission and it doesnt slip at all, with the shift sylonoid plugged in the transmission it doesnt go into gear but with it unhooked it moves and goes into gear
1997 Honda Accord
2016 jeep patriot
Old 07-18-2012, 02:09 PM
Re: 02 neon 2.0
Sounds like the solenoid is going bad then or maybe a sensor. I am not familiar with the 2nd gen transmission but I do believe it has its own computer, correct?
2003 Dodge SRT-4
Old 07-19-2012, 01:00 AM
FORDGUY09's Avatar
Re: 02 neon 2.0
its own comp yes i think so. i had done a heater core in the car and didnt see a comp in the normal spot but was told the comp or a comp (ecu) is under the window washer fluid res. on the pass side of the car
1997 Honda Accord
2016 jeep patriot
