99 Transmission problem
I have a 1999 GMC Suburban(5.7) with 173k miles. When the outside temperature is above 80 degrees F and I have been driving for about 30 minutes, I get a hard/firm shift from 1st to 2nd. It shifts to the other gears normally. When the temp is below 80 degrees, I can drive all day without any problems. Any clues for what may cause the hard shifting on hot days?
Re: 99 Transmission problem
I would get a transmsson capable scanner on it and also pull pan and check valve body springs and spacer plate area for problems. Post back any transmisson or engine codes.
