Old 07-13-2012, 07:57 AM
big white bufflo big white bufflo is offline
power steering winning
my wife 2003 windstar power rack devolped a leak replace that then the pump would not quiet down so i replace that it been together for 3 days and will not stop winning i have read about air in system should i give it time or is it posible the hoses were put on at the rack wrong
Old 07-13-2012, 09:00 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: power steering winning
Did you bleed the air from the system after the repairs? If not, you need to. In some cases a vacuum bleed is needed to remove all the air. I doubt you have the lines on wrong, they are usually different threads into the gear.
Old 07-13-2012, 09:27 AM
scubacat scubacat is offline
I bled mine by just bumping the starter about 5-6 times and topping off the reservoir after each time. Seemed to do the trick.
Old 07-13-2012, 06:20 PM
wiswind wiswind is offline
Replacement of the power steering fluid is highly recommended.
Use a synthetic ATF.....like Mobil 1 ATF....as power steering fluid DOES get quite hot and a non-synthetic fluid can break down quickly.
Also a synthetic ATF will give you improved cold temperature performance.
Old fluid is a very common cause of noisy power steering on the Windstar.
It can take some time to work all the air bubbles out....and you will have noise as long as you have them.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 07-15-2012, 03:11 PM
ajb0009 ajb0009 is offline
This is on topic a bit, but not a reply to your question. I have a 1998 Windstar with 3.8L; about 125k miles. I replaced the power steering pump a couple years ago with a reman unit. Has always had a pretty bad whine. I recently flushed the system with Lucas Oil full synthetic power steering fluid. The steering is much smoother, but it not do anything for the whine.
Old 07-15-2012, 04:50 PM
Windstartled Windstartled is offline
Pump bearing would be my first suspect then.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
01 sierra power steering went out after dounuts torj0752 Sierra 2 03-06-2011 10:46 PM
power steering firetbabe Grand Prix 9 01-21-2011 12:29 PM
No power steering assistance! amurillo Contour 7 01-11-2010 10:35 PM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
power steering problem cwb1333 3 Series 2 04-10-2009 07:49 PM
