Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 07-12-2012, 01:38 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Proper brake master cylinder sizes? Which size for clutch? Change pedal for hydraulic?
The GTS manual shows the brake masters at 7/8" and the clutch master as 3/4". However our GTRA has a 1 1/8" master for the rear brakes and 7/8 for the fronts. My clutch is currently manual, but I'm converting to hydraulic for the clutch and have seen people use master sizes all over the map on here. I.e Wirewheel sold a clutch pedal assembly and line with a 1 1/8" master. What's the proper size? I wouldn't want to push too much fluid through the throwout bearing.
Here you can see the left master is larger
This car for sale on Wirewheel appears to have the same thing going on i.e. left one larger (center one in this picture, left brake master). What size is that clutch master? The reservoir is obviously smaller.
I assume I have to change the clutch pedal when I convert to hydraulic? Anyone know the specific part? I assume wilwood would make the parts ince our pedal bodes are wilwood. Again the Panoz parts manual only has Panoz specific PNs.
Thanks,
Brian
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 07-24-2012, 04:17 PM
eric1h eric1h is offline
Re: Proper brake master cylinder sizes? Which size for clutch? Change pedal for hydraulic?
I used a 1" clutch master, it allows for a short travel and plenty of force!
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
The Following User Says Thank You to eric1h For This Useful Post:
Cobra4B (07-24-2012)
Old 07-24-2012, 04:18 PM
ohh, and i ordered my GTS clutch pedal from Wirewheel, they had a few in stock last I checked.
Brakes Dragging After New Brake Booster and Master Cylinder shermancelmare Cherokee 3 05-20-2012 04:39 PM
Brake Master Cylinder Cap For Sale drstroud Malibu 0 07-09-2004 03:15 PM
1999-2000 Brake Master Cylinder Cap For Sale drstroud Grand AM 0 07-09-2004 03:11 PM
