Old 07-10-2012, 05:20 PM
helicopter23 helicopter23 is offline
Strut mount completely rusted
Took car to a mechanic and he showed me the strut on the driver side back is rusted out and it's only a matter of time before strut goes into the trunk. He said there is no way to fix this.
Is there anything I can do and what is parts and labor gonna be for whatever can be done.
Old 07-10-2012, 05:52 PM
rickisrad rickisrad is offline
Re: Strut mount completely rusted
a body shop has to take care of this. costs can vary big time, I took an old escort in one time for this issue and it cost me $350. most places would give you a free estimate
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 07-10-2012, 06:11 PM
$350 and I'm in.... I also need a hose replaced and a new muffler/cadalliac converter that's gonna cost me $400 with parts and labor..... If I can get the strut mount that's rusted out for around $350 I will get all the work done instead of junking my 97 grandprix gt with 145k.
Old 07-10-2012, 06:35 PM
just take it around for estimates. a belt and aftermarket cat can be installed yourself for less than 400 bucks. easy things to replace.
Old 07-10-2012, 06:40 PM
here is a youtube video of someone fixing the same problem. http://www.youtube.com/watch?v=xuSab0MPftY
Old 07-10-2012, 08:41 PM
Tech II Tech II is offline
When you see body rot like that, you have to wonder about the other side, the front cradle, brake and fuel lines, etc.
Old 07-10-2012, 08:56 PM
Yeah definately. For some reason the grand prixs leak at the body seams and run down the strut tower. A lot of times if you look you can see a small water trail/rust stain. I usually take sand paper and clean the area off and spray rust preventative spray then plasi dip to protect the area afterwards. I have done it to my past 3 grand prixs when changing the struts. My friends grand prix rusted out in the same place.
Old 07-10-2012, 11:35 PM
The other side was 98% rust free, is was fine. Don't know about the brake and fuel lines.
Also the mechanic said my car's temperature's reason front running high was because of a leak in a hose, not what I thought which was the 2 gaskets.
Roll Cage Mountings carbuilder2002 F1 4 07-11-2012 07:10 AM
