Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 07-09-2012, 10:43 PM
randyknight randyknight is offline
Cooling issue for 2003 Acura TL
I have an 03 TL that I have a cooling issue at idle. It started with just the A/C not blowing very cold at idle. Then it started heating up unless I turned off the A/C. Now on a hot day I have to shut off the engine at a red light in order to not overheat. Coolant reservoir is full.
It also has two codes. P0122 and P0740, neither of which appear to be cooling related.
Old 07-10-2012, 11:51 AM
somick's Avatar
somick somick is offline
Re: Cooling issue for 2003 Acura TL
Check out your coolant level.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 07-10-2012, 10:38 PM
grease_monkey1975's Avatar
grease_monkey1975 grease_monkey1975 is offline
p0122 is the throttle position sensor, check your wiring to the sensor and make sure it has volatage
p0740 is a code for your torque converter which is a transmission issue (not my strong suit) have a tranny shop check it
The over heating issue check to make sure your fan(s) are coming on? sounds like they may not be? Does teh temp go down if you turn heat on? If it does your thermostat is bad, lastly might have a partial clog in system somewhere
Programming keyless Entry for 2003 Acura mseebeck CL | Inspire | Saber | TL 1 11-05-2005 05:15 PM
2003 Acura Mdx Premium For Sale!!! mdx88 MDX | Pilot 0 11-21-2004 02:43 PM
Programming Keyless Remote for 2003 Acura TL - Type-S phinanz Interior | Audio | Security 0 04-07-2004 05:30 PM
