01 Silverado ashtray light
The ashtray light in my 01 Silverado appears to be burned out. I don't smoke and only use the tray to keep stuff in and would like to see into tray at night. I pulled the tray but can't see how to access the bulb, I see no screws holding the tray mounting bracket in place. Anyone know the procedure for changing this bulb?
2001 Z71 ext cab |
Re: 01 Silverado ashtray light
1. Ensure the headlamp switch is in the OFF position. 2. Remove the knee bolster. 3. Squeeze the sides of the instrument panel storage compartment. 4. Pull out the compartment. 5. Remove the ashtray assembly by unsnapping the retainers. 6. Remove the lamp assembly and the shield from the top of the ashtray bracket. 7. Remove the shield from the lamp assembly. ![]() ![]() 8. Remove the bulb from the base by pulling the bulb straight out of the base. ![]() ![]() 1. Install the bulb into the base by pushing the bulb straight into the base.
2. Install the shield to the lamp assembly. 3. Install the lamp assembly and the shield to the top of the ashtray bracket. 4. Install the ashtray assembly to the instrument panel. 5. Install the instrument panel storage compartment. 6. Install the knee bolster. Last edited by gmtech1; 07-10-2012 at 08:03 PM. |
| The Following User Says Thank You to gmtech1 For This Useful Post: | ||
Aslag (07-14-2012)
Is the "knee bolster" the lower trim piece below the ashtray and the 3 power ports? And is the "instrument panel storage compartment" the panel that contains the power ports and ashtray? Thanks
2001 Z71 ext cab |
"Knee bolster" is the trim that runs under the steering column, lower dash, that your knees are level with. I/P storage compartment is the glove box.
Aslag (07-14-2012)
The links given for Removal Procedure and Installation Procedure result in: “You are not authorized to view the requested information.”
Because you are not authorized. I think the instructions are pretty self explanitory.
How about LED for the Ash tray?
