Old 07-08-2012, 09:45 AM
ThanksForHelping ThanksForHelping is offline
97 climate control issues
Hello, all! I have a 97 GT that has the heat stuck on and no a/c. You can imagine the discomfort in this heat wave! I believe there are two different problems; the a/c needs charged and maybe the temp. control knob is detached or inoperable. Is it electrical or does it use cables? There is very little tension at the knob. Engine temp. stays well within the normal range. Am I on the right track? Any other suggestions? If you think I'm correct, how do I fix it? Thanks.
Old 07-10-2012, 06:05 PM
rickisrad rickisrad is offline
Re: 97 climate control issues
all of the controls are electrical. I would have to say start with replacing the switch that controls the on off function that way you could stop the blower from putting out hot air. if it is just the temp control switch I am sure you could find one used at a junk yard, Morads auto parts, online, or in the stores cheap. I would be willing to bet that you have a hole in your condenser causing your AC not to work/blow cold. look at the condenser through the opening in your front grille and look for "wet" spots from a rock hitting it. If you do decide to put freon in it make sure you use the kind with the leak detecting dye.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
The Following User Says Thank You to rickisrad For This Useful Post:
ThanksForHelping (07-14-2012)
Old 07-10-2012, 06:25 PM
brcidd's Avatar
brcidd brcidd is offline
A '97 W car as is yours will have a cracked gear inside driver's side temp door actuator motor- above gas pedal- remove 2 5 mm screws and remove and unplug actuator- then either put a new gear in it or replace actuator for $90 or so...look for lack of rotation to verify failure mode - but they are always stuck on heat..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
The Following User Says Thank You to brcidd For This Useful Post:
Old 07-14-2012, 12:35 PM
Thanks, guys! I was about to tear into the dash to do some exploring when I decided to check back here. You've saved me a lot of work and headache and it is greatly appreciated.
97 Climate Control Display Gone Cramill Bonneville 2 10-11-2011 11:30 AM
stereo wiring & dual climate control enslow LeSabre 21 06-27-2011 03:40 PM
Unable to adjust climate controls..? ArdiniA Caprice 3 01-06-2010 08:05 PM
AC/Climate Control '02 Silhouette (Venture) andante147 Venture 0 06-24-2009 01:47 PM
Climate Control issue CivicRacerX Car Audio 2 05-09-2003 12:03 PM
