Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 07-07-2012, 09:39 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
98 Avalon codes 302-304-306 and 300
3.0 V6 fed. 137 K mileage
Also lean and rich bank 1 codes 171-172
Cleared codes and now has low count of ramdom miss on all cylinders on missfire reading.
Engine running rough and miss at idle and low speeds and slow take off.
Runs good at higher rpm.
Any help or ideas.
Thanks
MT
Old 07-09-2012, 12:30 AM
Joe W Joe W is offline
Re: 98 Avalon codes 302-304-306 and 300
Lets start with the basics, when was the last tune-up and what did it include... plugs, wires, coils?
Old 07-09-2012, 09:37 AM
MT-2500's Avatar
AF - Advisor
Thanks
That sounds like a winner to me.
I just noticed it is 237K instead of 137K.
Will also check compression.
MT
Old 07-09-2012, 06:01 PM
MT-2500's Avatar
AF - Advisor
Originally Posted by MT-2500 View Post
Thanks
PULLED PLUGS AND RAN COMPRESSION TEST.
Found problem.
Rear cylinders at 210 lbs and front cylinders at 110 lbs.
Front camshaft must be out of time or belt slipped.
MT
Old 07-09-2012, 08:55 PM
That extra 100k will make a difference! Good idea to check the compression. Let us know what you find as the cause for the different readings!
302 vs. 351 vs. 300 geodiggr F Series 23 02-07-2017 07:08 PM
03 alero code 340 cam position sensor and 300 multiple cylinder misfire cfegenbush Alero 3 01-19-2010 01:33 PM
2006 Saab 9-5 codes 1301 and 300 nero11 9-5 0 08-06-2009 09:45 PM
Code P301-304 notkidding '97+ 17 02-27-2006 11:19 AM
97 Avalon. code 135 ??? NiteRida Avalon/Pronard 2 05-26-2004 12:58 PM
