Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-04-2012, 03:49 PM
totalpackage's Avatar
totalpackage totalpackage is offline
Need id help on this 1996 Tahoe part
I have this 1996 4x4 Tahoe 2 door with a 350 vortech.
It recently started squeeking when you get in it and as it drives. I can shake the Tahoe and here it clearly and have identified it to this worn out rusted part on the front right side by the wheel. Can you tell me what it is. It has the tranparent piece of white plastic surrounding it and is rusted. It moves up and down when you shake the truck. Stabilizer? Shock?
Old 07-04-2012, 10:18 PM
j cAT j cAT is offline
Re: Need id help on this 1996 Tahoe part
Attachment 46165
looks like the stabilizer bar links. if so these bushings are replaceable.
I like to replace the bar bushings also .
The Following User Says Thank You to j cAT For This Useful Post:
totalpackage (07-05-2012)
Old 07-04-2012, 10:57 PM
Thanks, but I can not locate any of those named items in the LMC manual.
http://www.lmctruck.com/icatalog/CSD/full.aspx?Page=101
Any other name for this? Or am I overlooking it?
Old 07-05-2012, 08:55 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
They are not shown on the image you provided. Any parts store should carry them.
AKA sway bar links.
The Following User Says Thank You to gmtech1 For This Useful Post:
Old 07-05-2012, 09:14 AM
LOOK HERE ,,, http://www.lmctruck.com/icatalog/csd/full.aspx?Page=94
they call this sway bar bushings. rod end bushings.
Old 07-05-2012, 09:25 AM
also advance auto has these check out for reference http://shop.advanceautoparts.com/web...ip2HomeClicked=
Correct Procedure to R&R transmission on 1996 Tahoe 4x4 5.7L marklar34 Tahoe 0 12-10-2009 01:16 AM
New to board, need help with some tahoe troubles MisterTAW Tahoe 3 07-10-2007 02:01 PM
New to board, need help with some tahoe troubles MisterTAW Tahoe 0 12-18-2006 01:37 PM
Woman needs help with 97 Tahoe, surging, Is the timing bad? Tucci Tahoe 8 02-03-2005 03:06 PM
hurricane victim needs help! NO 4WD! tahoe joeybagodonuts C/K 4 09-18-2004 03:53 PM
