Old 07-03-2012, 01:39 PM
Hemi Killer Hemi Killer is offline
I think I figured out my painting problem? Help with PSI
I had another thread about my painting woes. No matter what I did, the paint or clear would never settle and flatten out.
I started messing with my compressor and airbrush. I have a badger compressor. Its entry level. No switch, just turns on when its plugged in. I had to buy an aftermarket regulator for it also. So Im thinking is a cheapo, not sure what I paid for it.
anyway, I set the dial to 12 for Alclad, 20 for other stuff, etc. No matter what I set it on, when the button is depressed, it never had more than 15 PSI.
Im wondering if this could be the cause of my painting problems. I know most people spray this stuff at 20-30 psi
thanks
Old 07-03-2012, 02:34 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: I think I figured out my painting problem? Help with PSI
Increasing your spray pressure is not going to help to flatten out your paint. It's more likely to do the opposite.
If your pressure is too low, it will usually result in unreliable atomization of the paint. You'll be able to tell because the airbrush just doesn't feel like it has enough power to consistently feed/spray paint. Generally you want to spray with the lowest pressure that the airbrush and paint will spray at, and increasing the pressure much beyond that can cause orangepeel.
But if your compressor now won't generate above 20 or so, you may have a bit of a leak somewhere. Teflon thread tape (plumbing section of your local hardware store) is very useful for mounting regulators on compressors.
You might try adding more thinner when you paint, and spraying in light, wet mist coats. I hardly ever spray anything with more pressure than 15-20.
PHOTOBUCKET SUCKS
Old 07-03-2012, 05:06 PM
Thanks for the help. The airbrushes have been spitting and sometimes every 3 seconds or so there is a break in the air. Theres no power switch im just kind of iver it. I have two identical paasche airbrushes so i know they arent the problem. Theres no leak i yhink its just a bottom of the barrel compressor.
I just got a good deal in a Grex i just picked up drom the LHS. Max psi is 60. Maybe thia one fix my painting issues all together but it will eliminate all yhe other annoyances. Ive had it six years So the upgrade is justified
Old 07-03-2012, 05:35 PM
stevenoble's Avatar
If it's the same Badger compressor that I started out with then its junk. It never used to get up to a good pressure and also when you sprayed the pressure would drop because it had no storage tank for the air. It used to use air as it was produced and it couldn't make it fast enough. I used to find myself waiting for the compressor to catch up all the time. Bought myself a better compressor soon after and it was the best move I ever made..
Steve Noble
The Following User Says Thank You to stevenoble For This Useful Post:
Hemi Killer (07-03-2012)
Old 07-03-2012, 06:06 PM
brand new the compressor was no more than $70-$80. Thats what it seems like, it never produces enough air.
Old 07-03-2012, 08:43 PM
Archetype123 Archetype123 is offline
I had the same sort of case...
I bought a sort of 'airbrush in a box' kit. It was a Testors setup... It was horrible to say the least.
But, what sold me on it was that it came with a compressor. Nothing fancy... Much the same as yours. Plug it in, flip the switch and it was 'on'. No regulator, no nothing. I thought this was the right way to do things. It was my first time holding an airbrush. The only thing I knew about airbrushing Tamiya acrylics is that I had to thin them. LOL.
This thing would shoot out what felt like 100PSI at times, it was brutal. My skills sucked a big one, the airbrush it came with was garbage, and I felt totally discouraged/disheartened.
Let me tell you this, this DEFINITELY the case of the bad equipment. The operator can only be so good before what you're working with just seems like trash. I bit the bullet... Got myself an Iwata HP-C Plus and an Iwata Smart Jet compressor.
With proper pressure settings on this bad boy, my results were night and day to my crappy old Testors piece. I don't want to say that spending the kind of money I did on an AB setup made me a better painter, but man, I really can't deny it. Results speak for themselves, and there's nothing like fighting with crummy equipment.
I liked it so much, I got myself an Iwata Revolution BCR to take care of spraying bodies (0.5mm needle/siphon fed).
Anyways, HK, I hope you solve your painting woes sooner than later. We've all thrown some kits in the trash (I'm guilty of it... double digits.), but practice makes perfect. Best of luck.
Old 07-03-2012, 10:36 PM
MPWR's Avatar
That does sound like insufficient pressure could be your problem.
I bought a Badger diaphragm compressor like this-
-many years ago. Well over two decades later, it is still going strong. I can't say it is the only choice or necessarily the best choice, but it has always been entirely sufficient for all of my airbrushing needs (once I added the regulator).
PHOTOBUCKET SUCKS
Old 07-03-2012, 11:12 PM
one of the biggest problems was RIGHT at the end of painting my F40 for the second time, literally right before I stopped, it sputtered and shot chunks out. The cup wasnt empty. Its made more work for me many times, so Im happy to be done with it. The new one is setup and I will use it tomorrow.
Old 07-04-2012, 12:14 AM
CFarias's Avatar
CFarias CFarias is offline
When buying hobby style compressors it is important to get one that exceeds the pressure you would normally spray at. This is because you will loose pressure within the hose, the airbrush, from the paint and thinner, and especially through the regulator and water trap. A compressor that is rated for 25 psi may pump out 15 to 20 psi at the airbrush because of these pressure losses.
So it is a good idea that if one is going to buy a hobby compressor that a medium to high end model is selected and one that says right on the box what the pressure should be. I would recommend getting one that is rated for at least 100% more pressure than what one would expect to spray at. For example, if 30 psi is the desired airbrush pressure then a compressor rated for 60 psi should work.
As a side note...the pressure ratings for compressors are at the compressor outlet with no load put on them from an airbrush. And, the regulator is telling you how much pressure is going through it and not how much pressure the compressor is putting out (more than what the regulator says) or what the airbrush is putting out (less than what the regulator says).
The Following User Says Thank You to CFarias For This Useful Post:
Hemi Killer (07-04-2012)
Old 07-04-2012, 12:49 AM
yeah this one is rated at 60 PSI.
With the brush held open constantly, it maxes out at 20 PSI, but if I feather it as I go side to side (like a spray can) it maintains pressure and only takes about 1 second to bump the pressure back up.
th regulator is built in. It also has an auto shutoff when it reaches the set PSI, it has a small reserve of air.
I need to work on my technique, once I get that down I think this compressor will be perfect.
Old 07-04-2012, 01:15 AM
CFarias's Avatar
Good luck and I hope things work out for you.
There are other options for hobby compressors if it comes to that. The home-garage style compressors that you'd find at the hardware store usually come with a tank, and almost always pump out at least 90 psi. These are great as they can be used for airbrushing and around the house for air tools and footballs and such, but they make more noise and are heavier to move around and are inconvenient for apartment dwellers. Still, they almost always come with a regulator and moisture trap and often times can be in the same price range as a hobby compressor.
I opted for a CO2 system. It is the ultimate in quietness since there is no compressor. A charge of CO2 lasts me two years and costs about $25 to replace. Also, there is no need for a moisture trap. It is heavy, but you can get smaller, lighter, CO2 bottles. A typical setup can cost less than $150.
Old 07-04-2012, 05:06 AM
stevenoble's Avatar
That's all good advice and I would agree to always buy a compressor that will give more pressure than you will ever need, simply because the compressor is not working as hard to produce the pressure you spray at if it can produce double or more the pressure that you need...
Steve Noble
Old 07-04-2012, 03:17 PM
John18d John18d is offline
Hemi killer - I live in an apartment and I use a 1/3 hp compressor with a 3 gallon tank that I got from "Harbor Freight" tool for about $50 on sale - it came with a built in regulator - a water/moisture trap cost an extra $14 with a pressure regulator built in - I've been using it now for about 5 years and it works great - it's not that noisy - none of my neighbors have said a thing or ever complained - they don't even know I use it as far as I know. The tank holds enough air at up to 100psi so that the compressor doesn't run that much - the tank has sufficient air supply to paint most things before the air supply runs out. two things to consider with any air spraying system is "pressure" and "volume" they are not the same thing - many people by those little "hobby" compressors, but are soon disappointed - the compressor runs full-time and the "air" spurts out of the airbrush "gun" in rhythm to the compressions of the compressor. The air pressure is neither "constant" in volume or pressure. Thus the results are poor. With my system which is really a cheap system The compressor runs briefly - fills the tank - the auto systems shuts off the compressor and I spray off the supply in the tank. When tank pressure drops to 50-60 psi it switches back on and fills the tank again. in most all cases I'm finished spraying the object "model" before the compressor turns back on. I get a nice steady constant stream of air plus I use a "micro" inline regulator right before the airbrush to make small changes to the air delivery rather than changing the line pressure at the tank regulator which is set to 40psi and I never change. pm me if you want to discuss any of this further - John
Old 07-04-2012, 06:02 PM
Thank you John. I have a large compressor in my garage. I am not willing to set up my airbrush stuff in the garage because its 110+ 3-4 mnths out of the year here.
this is what I bought. It was an early Bday present from my wife.
http://www.grexusa.com/grexairbrush/...p5?id=AC1810-A
Old 07-04-2012, 10:10 PM
Hemi Killer - not to slant you, but I don't think you'll be happy with what you have. those type of compressors with no storage tank will not provide adequate "cfm" to produce overall quality finishes on the surface of a model. It will be satisfactory for spraying "very small" areas "one or two pulls of the trigger" but it will not be sufficient to spray a car body with paint or better yet clear. I may me mistaken, but the compressor that you have is more for a "nail polish" salon type use. The hp of a compressor will determine the psi it can achieve, but "cubic feet per minute" is a measure of volume and that has no bearing on the compressor's hp - when you pull the trigger on the compressor type you have the psi and cfm will fall to zero because it cannot maintain a constant "cfm". This is true of all small compressors and in general any "home/garage" compressor without a storage tank. Where the storage tank comes into play is it holds enough "volume of air" so that when you pull the trigger to spray a "car body" with paint or clear you will be able to pull the trigger 20-30 times before the psi starts to fall because the "cfm" volume has decreased. 20-30 pulls of a trigger has been plenty of "volume of air" to paint something in the modeling world and I have worked on models up to 1/8 scale without any problems. Give your unit a try, but I feel you'll be returning it if you want a compressor for general use for airbrush application. I understand your not wanting to spray in your garage - I used to live in Laughlin NV for many many years - very often the hottest place in the USA during the summer - and even here in Tucson our average summer day is 105 degrees Fahrenheit. I don't spray outside either, but for me my small unit with tank works indoors and I vent the over-spray thru my paint spray hood out the window vent so the apartment doesn't fill with fumes. I spray mostly "Zero" paints and 1K and 2K clears. I also use Tamiya "enamel" flat and gloss paints that I get from Japan. Hemi Killer - have you considered running a hose with a manifold containing a regulator and water/moisture trap into the house where you work on your models?? You could turn on your garage compressor when you wanted to use it and then turn it off when not in use, and this way you can work indoors? You will still need to vent the over-spray and VOCs as your house will become inundated with toxic fumes - especially if you spray anything like 2K clear or paints that use any type of catalyzer to harden the paint. Most all these types of finishes use cyanoacrylate "super glue" for the hardener and that is not good for the lungs. Hemi Killer PM me at your leisure and we can discuss this more after you try out your compressor. - John
The Following User Says Thank You to John18d For This Useful Post:
Can anyone help me figure out what is wrong with my 93 probe?? Ms. Confused Probe 3 12-10-2005 12:32 PM
I figured out the problem with my door but know i dont know how to fix it? rcarter13 Explorer | Explorer Sport Trac 4 07-10-2005 01:00 AM
Help! Can't figure out my problem roblbenson C/K 3 02-13-2004 10:57 AM
Hey Guys - I figured it out - new problem- help please ricodemus '88 - '91 Civic | CRX | Wagon | Shuttlee 6 05-28-2002 02:22 PM
