Old 07-02-2012, 06:21 PM
rusnamps rusnamps is offline
1998 k2500 4x4 fuel pump problems
Ok, I have a 1998 chevy k2500 with the 5.7L vortech and what keeps happening is my fuel pump stops pumping...I have tried taking it to a dealer and they said that the only thing wrong is the fuel pump and changed it (that pump lasted 2200 miles)......I am on my 9th pump I have tried EVERY brand....it runs perfect for the 1st 15 starts after that you have to cycle the key 3-10 times to build up pressure so it will start. Once started it runs great no fuel problems..let it cool and you have the same problem again...... on the last stages of pump failure you have to spray a 1 sec burst of starting fluid to get it over the hump then it will run....also as it begins to fail the normal whine of the pump gets quieter till it makes no noise at all (at that point it it bad)..if any1 can take a stab at what might cause it to go out so often I would appreciate it.
thanks James
Old 07-02-2012, 06:52 PM
Bob B Bob B is offline
Re: 1998 k2500 4x4 fuel pump problems
Hi,
The wire harness to the pump at the tank has a wire that goes to the frame rail for a ground. has it been checked? Or unscrew it next and check. Clean t5he metal on the frame and the connector then retighten.
My 97 was on the left.
Bob B
Old 07-03-2012, 10:18 AM
I replaced the connector from the pump did not see the ground screw/bolt to the frame, I will look tonight and see if that will fix it.
Thank you for your post Bob.
Old 07-03-2012, 10:37 AM
Schurkey Schurkey is offline
Nine pumps and no diagnostic work done?
1. Sediment in the tank destroying the pumps. Thoroughly clean or replace tank. You are replacing the inlet prefilter, right?
2. Electrical supply to the pump is defective. Test voltage (as close to the pump as possible), current, and if possible, use automotive oscilloscope with a "low amps" probe to check pump instantaneous current draw and motor speed.
2B. Earlier vehicles have a known problem with the wiring of the sending unit; perhaps yours also. The wires INSIDE THE TANK on the sending unit get burned from poor design and excess current. Many fuel pumps come with a replacement wire harness. Did your pumps have a wire harness, and was it installed?
3. Plugged fuel filter, or restricted plumbing creates excess pressure; prematurely wears out pump.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 07-03-2012, 03:17 PM
j cAT j cAT is offline
If the dealership replaced the pump and it failed after 2500miles what did the dealership say ? do you ask for any free fix for their failure to correct this ?
the fuel pressure need be tested. 60-65psi is what is required. when replacing fuel pumps on old vehicles like this the relay also must be replaced. obviously the fuel filter.
the pump to use would be the delphi pump. if this is an air tex pump then this would explain all these failures.NEVER USE AIRTEX.....
WHEN A PUMP IS REPLACED YES YOU DO THE FUEL PRESSURE TEST AGAIN ! make sure all is good.
the frame rail ground next to the fuel tank driverside is the ground for the pump etc...
cut open the fuel filter to examine for contamination.
Old 07-03-2012, 05:28 PM
Ok in reply to Schurky.......I Have had Diagnostic work done on it as well as testing the fuel PSI (before and after the new pump) new is allways around 65psi old is in the low 20s or lower more times then not. The tank has been repalced for shi** and giggles so its not a crap in the tank problem that i know of..........all filters are replaced every time the pump is. Now my first thought was that the return line was blocked making the pump work harder to keep the proper PSI on the return side however according to the dealership that is not the case. Also, I did not list EVERY time that the 3 dealerships in 2 states have run tests on the truck for sake of running on.......but at least 6 full work-ups have been done (i payed for 3 because I kept dealer hopping). Now to reply to J Cat, Like i mention above the filters have all been change or atleast I was billed for them as I was not the one replacing them. I will try replacing the relay and will cut open the "old" filter and see if anything is in it, I am allmost to the point of scrapping the truck but it has under 50k miles on it......Oh and the wiring harness that connects to the pump has been replaced twice as I was told that was a common problem...
Old 07-03-2012, 05:33 PM
I forgot to mention that I Did find the ground and it was a little worse for the wear so I replaced it and sanded the frame where it attaches (it did have continuity so it was not compleatly bad).
Old 07-03-2012, 06:47 PM
the return line if restricted will cause high pressures. this is restricted when testing to see if the pump can produce pressure above 65 psi. for a very short time. pinching the return line.
so check the filters for contamination. also find out if the pump was a delphi pump.
the other thing is make sure at all times you keep the tank at 1/4 or more of fuel as this will damage the pump if running low on fuel will overheat the pump.
a bad relay or even a loose fuse socket will cause the pump to run hot and not at the proper speed. so too a bad corroded ground..
since the fuel tank was replaced then debris like a piece of plastic wrap is not the cause of low pressure. one time I had a person find a condom in the fuel tank causing this type issue.
it is possible the fuel tank venting system is plugged up creating a high vacuum. could be cannister or and lines full of charcoal . this occurs from overfilling fuel tank and then parking rather than burning off the excess fuel before it can expand into the cannister . if liquid fuel enters the cannister this is bad..
The Following User Says Thank You to j cAT For This Useful Post:
rusnamps (07-03-2012)
Old 07-03-2012, 07:45 PM
777stickman 777stickman is offline
Continuity is one thing. Running volts and amps thru a "not completely bad" connection is an entirely different thing. Sure hope that you get this figured out.
One other thing that hasn't been mentioned is to keep your tank above 1/4 full. Less than that causes the pump to loose cooling from the fuel.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
Old 07-03-2012, 08:47 PM
the replacement pump was a Bosh... I have a Delphi that i plan to replace it with....I also just installed a new presure regulator (major pain in the butt to put in) and filter, the old one seemed semi clean when i cut it open. I hope by replacing the pressure regulator and ground connection my problem will be fixed.
Old 07-03-2012, 09:58 PM
Blue Bowtie's Avatar
Registered Offender
Did you set the FPR when you installed it? Most come out of the box a few PSI off the optimal setting. Once the intake is opened, adjustment is pretty easy:
Old 07-03-2012, 10:29 PM
I see this mentioned frequently, and I do not understand it.
The pump has nice, cool fuel being pumped through the middle--how can it overheat just because the outside isn't submerged?
Old 07-04-2012, 07:49 AM
with all the different pump manufacturers used, the wiring at the pump and splices into the OEM wiring should be soldered and heat shrink with electrical insulation to insure a good electrical connection for the pump power which does draw a few amps.
the fuel filter should look slightly dark if it has a few thousand on it . remove the filter from the frame and you should see light thru the filter media. it you cannot see any brightness when placing a light at the other side of the media then the filter is restricted. with a filter this little used perhaps the fuel supplier used is to be avioded.
Old 07-04-2012, 08:57 AM
Blue,
nope...i just took the default fpr..hope it won't be a problem, the truck seems to run ok with the new pump in...the pump sounds different then the old bosh, sounds stronger and more consistant. thank you for the pic too, wish i had that yesterday would have saved me a lot of time finding the fpr.
Old 07-04-2012, 09:03 AM
Also as far as the wiring I removed the old butt splice and soldered and heat shrinked it as well (as a electrician i hate butt splices) and the filter did not show light through it b4 i cut it in 1/2 however it did not have much if any crap in the gills...it was a light brown color with a few dark green spots.
Starter/fuel pump problem xum Caravan | Voyager 1 10-08-2011 10:57 PM
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Tags
fuel , low , pressure , pump
