Old 07-02-2012, 02:49 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
untitled- Mk1
Yes untitled, since I lost minutes trying to get a name.....
I'll try to give you one idea of what I have in mind......
It would be something like a '20 boardtracker, speaking of general appeal, but it would be built on a softail frame (call it shortcut.... but the frame is... nice... )
The engine is the stock 80 inches evo but I want to use shovel heads over.
The "main topic" however, is another: my first laced rims.
A couple inspirational shots: it would be a mix of the following with some "gio"'s touches
(images taken from Lowride 4 and5/2009 just for discussion)
Like other times I started design and etching few special parts
My ita friend Disca asked me what was those squashed seagull bird in the PE set...
it is my fuel tank!
Now one accurate brazing job wait me.
Time to speak about my rims odissey... I started with resin turned rims.... they worked well until I discovered that I got 40 spokes and 38 holes..... dammn gio... maths is not my better side....
Time for the battle, I decided for the heavy way... get alu rims! (7075 ergal to be fine...)
My lathe wasn't enthusiast to work with those huge parts... but at last it worked decently....
All I needed then was a million nipples (most tedious job I done ever), drill and to enlace spokes (nipples done with syringe bits cutted and filed, spokes with 0.36 plain steel chors for guitar)
and so.... ladies and gentlemen I'll introduce you my first scratchbuilt latched wheel....
it work better now uh?
I guess I would be busy next months... million latched wheels to do for my ducatis, guzzi, harley..... indians...
stay tuned!
gio
Old 07-02-2012, 04:26 PM
auw12's Avatar
auw12 auw12 is offline
Re: untitled- Mk1
My word... I just love your style of keeping trying new stuff, which makes you... young... Great work buddy, as always~
Old 07-03-2012, 02:15 PM
stratos75's Avatar
stratos75 stratos75 is offline
Re: untitled- Mk1
outstanding job
Best regards, Mikhail
Old 07-03-2012, 02:52 PM
gionc's Avatar
Authorized Vendor
Re: untitled- Mk1
Thanks guys! Said by you two badass has double value!
gio
Old 07-04-2012, 08:05 AM
utzelu utzelu is offline
Re: untitled- Mk1
I am speechless - photoetched tank, lacing... great work.
Could you tell me what lathe did u use for turning the aluminum rim? I am in the process of buying one for exactly the same purpose - custom parts for model cars/bikes, specially turning wheels/rims. I was thinking about Sherline lathe.
Thanks and Regards,
utzelu
http://scalemodelsadventures.blogspot.com
Old 07-04-2012, 09:31 AM
gionc's Avatar
Authorized Vendor
Re: untitled- Mk1
Ask to Andy/MPWR about the sherline: he uses one. As far I'm aware about it is fantastic stuff. It is also not cheap but for us overseas guys may be a good choice with decent $/€ rates, I'm thinking by ages about a Sherline CNC mill.
BTW I have a Einhell lathe, it is a classic chinese minilathe (search minilathe on google...) only a little better assembled, not enough to do decent jobs: you have to completely rebuild adjusting sliding surfaces and tolerances. BTW I think the most important things are good sharp cutting blades and the sensitivity on your hand to know when the lathe/material/knife combo is working bad due height adj. or other factors.
To fill rims isn't the easiest option: you have to fill "inside" and this way ask even more by you... and you must to fill keeping the bar/tube with the chuck fingers, so you keep just a small lenght of the tube.... not safe job for novices, better "take hand" filling small diameters inside the chuck before....
I think the Sherline lathe (they offer several) is small and good for small parts, but ask Andy and sure he'll give advice, or take a visit to the machining area here on AF.
Sorry for rude english.... I type quiccccckkkkkkkkk!
gio
Old 07-04-2012, 10:19 AM
cinqster's Avatar
cinqster cinqster is offline
Re: untitled- Mk1
Fantastic job as ever Gio!
Hope you don't mind, but I am going to be critical about the rims! They seem to be suffering from 'chatter' were the cutting tool bounces across the metal and creates a pattern. I am guessing it may be because you are using the long cutting edge of the tool flat against the metal?
If that is the case, a good way to avoid this is to use the pointed tip of the tool and set the cross-slide saddle up at the angle of the cut eg. say 10 degrees of square for the rim edges. This will allow you to cut the angle cleanly with the tool tip. I know it's a real arse to set up when doing difficult profiles like rims, but the results are really worth it.
Forgive me if you know this already, but I thought it may also help other modellers wanting to do rims on a lathe!
Old 07-04-2012, 12:53 PM
gionc's Avatar
Authorized Vendor
Re: untitled- Mk1
Thanks man: TBH I know the stuff but also that is annoyng unmount the upper tower to rotate the saddle , but I agree: it worth!
For this time I was too much excited to try the whole work steps, from the rims filling to the strokes and nipples preps. up to the stroke latching, next time would be good to do few rims more so I'll rotate the saddle to achieve the angled filling, with the same angle for several rims....
Thanks!
gio
Old 07-04-2012, 05:53 PM
cinqster's Avatar
Re: untitled- Mk1
Great idea doing multiple rims in steps as it really is a pain to adjust the saddle each time! One thing that helps me is to draw a cross-section of the rim first, then make a list of the basic angles needed for each edge cut - makes setting up quicker.
If you need a source for stainless steel spokes, or tubes (0.1mm increments) let me know - I've found a great stockist in the UK at last!
Old 07-04-2012, 06:35 PM
quadzero's Avatar
quadzero quadzero is offline
Re: untitled- Mk1
Incredible, I really enjoy your builds. It's always an adventure watching you put something together. The rim is amazing, I look forward to more of this art piece.
Old 07-05-2012, 02:41 AM
gionc's Avatar
Authorized Vendor
Re: untitled- Mk1
Thanks Les, your post are ever motivating
Cinq. you've got a PM, obviously !!!!
gio
Old 07-05-2012, 03:30 AM
cinqster's Avatar
Re: untitled- Mk1
G, I didn't get the PM message - my account PM doesn't always work here.
Here is the website:
http://www.kcsm.co.uk/
They're very helpful and well priced. I got enough tubes and wires to do around ten 1/6th bike wheels (about 25 Euros). All I need is the time to make them now!
Tell them I sent you!
The Following User Says Thank You to cinqster For This Useful Post:
gionc (07-05-2012)
Old 07-05-2012, 09:07 AM
gionc's Avatar
Authorized Vendor
Re: untitled- Mk1
Their WS work in a strange way: btw at last I was able to lurke the pdf list: I wanted to ask, when they write "soft" does they meant the kind of tubes sold by Steve, those "really" soft that you may bend like solder or a softer "ever hard" kind of steel that can't be bent so easily?
This may looks odd but... it's important
BTW Thanks a lot I'll place a order and try the assortment is just impressive....
gio
Old 07-05-2012, 10:27 AM
cinqster's Avatar
Re: untitled- Mk1
Their website is a bit dodgy at times! Not sure about the soft stuff and wondered if it was the same too, as I've only ordered the hard stuff, so far. The hard 0.7mm x 300mm wire I've used for spokes will bend at a sharp 90 degrees very nicely - especially with good quality square shouldered jewellers pliers. If you not got any, buy some pliers with a 'box joint' hinge - they last much longer!
Good luck!
Old 10-03-2012, 03:37 AM
gionc's Avatar
Authorized Vendor
Re: untitled- Mk1
Hi fellows modelers
I have some progress to show, better I leave room to pictures since I lost the few wroten english I got being far from the AF!
Cinqster: I found all I hoped on those online shop.... and much more , also fantastic/friendly service and not expencive, not at all, at last.
parts/components:
we got a pair of shoes, finally
... and some other little goodies:
(secondary transmission belt is a old printer belt...
.. and for sure I would'n live without a wooden saddle...
I guess I may do one for my vintage bicycle.... LOL
very first tests:
and a surprise.... you may warm up steel rods in roder to achieve.....
...more to come
time to think at the saddle mount:
Yeah... now start to keep form: I'll add the "final" patina touch, in other words the character of the bike, as a final step, when I will see all the details together
Verrry first run, like the in the better garages, one illegal test without any license, brakes, exaust.....
And finally last touches:
thanks guys, see you soon ... more wood to turn in the lathe
gio
VW Golf Mk1 Fujimi 1/24 MattVW WIP - Street 5 07-24-2011 03:16 PM
Diorama pics with GOLF GTI MK1, larges flanges, 285 and 345/35/15 wheels.... pics.... GTI1800 Car Modeling 16 03-14-2004 11:43 PM
3 OTHERS GOLF GTI MK1......pics.... GTI1800 Car Modeling 5 12-08-2002 01:23 PM
VW GOLF GTI MK1 1600CC (FUJIMI), 17", brembo discs....orange... pics. GTI1800 Car Modeling 15 12-08-2002 10:30 AM
GOLF GTI MK1 16S OETTINGER...pics.... GTI1800 Car Modeling 15 11-13-2002 07:50 PM
