Old 07-02-2012, 09:10 AM
E9CAPT E9CAPT is offline
Cool HVAC noise
Greetings.
When I turn on my A/C, I hear a loud noise like something is leaking. It is intermitten and the faster I go, the louder it seems to get. It almost sounds like a leaking air tank. But the A/C works just fine. The noise does appear to be coming from the engine, its really loud when you wind down the windows.
Any suggestions would be greatly appreciated.
Old 07-02-2012, 09:21 AM
j cAT j cAT is offline
Re: HVAC noise
Originally Posted by E9CAPT View Post
Greetings.
when the ac compressor is on and you hear noises this means that the compressor has issues. could be the clutch is slipping and may need to be adjusted. check that the gap is .025 in area. if too big this will make noises.. also check the ac belt and tensioner for proper operation.
if this is not the problem then you may have a bad compressor or low refrigerent oil level. check for oil leaks around the compressor/check for proper charge.
post back how you corrected this.
sound issues are hard to figure out.
Old 07-02-2012, 10:27 AM
Re: HVAC noise
jCat-
This sure is a pain the a$$. It doesnt sound like a belt slipping. I checked all the 'easy' stuff. No leaks found. When am idling, their is no sound at all. Only when I am moving. Thats the crazy part.
Since it only happens when moving, could it be a vacuum leak or something with the emmisions?? But everything seems to be workign fine. Just the noise....ugh
Old 07-02-2012, 02:16 PM
Re: HVAC noise
jCat-
now it makes noise when the ac is ON and you are moving . with the ac OFF it makes no noise .
well you got me on that one !
what usually occurs is the exhaust manifold bolts break then you get these noises.. ac has no effect on this failure.......
Old 07-09-2012, 07:58 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: HVAC noise
E9CAPT,
What year is your Silverado? If you would like for me to check on warranty information, or want for me to check for any open recalls, please send me the last 8 digits of your VIN in a private message on the forum.
Kind regards,
Sarah
GM Customer Service
Old 07-12-2012, 12:20 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: HVAC noise
Does it have electronic or vacuum-operated controls? If they are vacuum, there could be a leak in one of the diaphragms that operate the diverter doors.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-12-2012, 08:39 PM
Re: HVAC noise
Originally Posted by jdmccright View Post
does it have electronic or vacuum-operated controls? If they are vacuum, there could be a leak in one of the diaphragms that operate the diverter doors.
this bring to mind what vehicle are we talking about ?
how to remove hvac controller carsarefunyes Grand Prix 1 11-12-2010 10:29 AM
Hvac GregGP Grand Prix 1 10-21-2010 12:01 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
2005 G5 - V6 Clicking Noise in engine donnap1957 G6 9 02-26-2009 07:44 PM
