Old 07-01-2012, 04:57 AM
Denisthemenace Denisthemenace is offline
Can I turn crankshaft without risking damaging valves if camshaft sprocket in UP position?(Honda accord 1990)
Just installed engine head wonder if I can turn crankshaft and balancing shafts freely if I don't have timing belt on,and camshaft sprocket UP mark pointing directly up? (I saw some of the valves abit open before I installed the head,)
thnks
Denis R
Old 07-01-2012, 07:50 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Can I turn crankshaft without risking damaging valves if camshaft sprocket in UP position?(Honda accord 1990)
A valve would have to be open a significant amount to bash a piston on yours I'm pretty sure. Turn the crank slowly, stop if you feel any resistance as you come to TDC or 180 degrees, I assume you've got the plugs out so you won't be fighting compression....use the shortest wrench you can get away with to turn the crank, that way if you do make contact, you won't have a lotta force behind it.
But I think you'll be fine.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
The Following User Says Thank You to jeffcoslacker For This Useful Post:
Denisthemenace (07-01-2012)
AC Expansion valve location for 88 Honda Accord LXi billgrego Accord/TSX/Accord Hybrid 0 05-29-2008 06:13 PM
How do I change an EGR valve in a 1996 Honda Accord? Bassett72 How-To's and Walk-Through's 0 06-19-2006 12:29 PM
Can I use the factory seat belts with new racing seats, Accord 1990 4 doors? How? Luisma55 Accord/TSX/Accord Hybrid 0 08-04-2004 05:33 PM
