Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 06-30-2012, 08:07 PM
sammmmmyyy sammmmmyyy is offline
2002 Trooper ABS and TOD
ABS code 43 , and TOD code 14,24,28.
I press the Auto 4x4, in the dash the Auto light flashes when i drive for a lil bit the check light starts to flash. i can put it into 4x4 Low, seem to work fine. Would the ABS sensors affect the TOD ? When i press the Auto button i dont hear any clicking from inside the truck. not sure if i should ? i just got the truck 2 weeks ago. got it used from a friend has 180,000miles on it. Any ideas before i pay for shop labor ?
Old 09-10-2012, 07:45 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 2002 Trooper ABS and TOD
Are you sure everything works fine when you put it in 4LOW? (In LOW range and the front axle is locked?) I don't have my manual handy, but I bet at least one of the codes m is saying the front axle isn't locking. There are 2 Vacuum Switching Valves on the front axle actuator assembly, 1 to lock the axle and 1 to unlock it. The VSV's can go bad (been there), a vac line can go bad or become loose somewhere, or the wiring to the VSV's could be bad.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-10-2012, 01:45 PM
I put the truck up on 4 jack stands and found that the 4x4 was not working in LOW and HIGH.
So i found the front VSV's . each have a line that goes to the axle. and they both are pulling vacuum with the switch on or off .
If i leave hose #1 on and remove hose #2 , with the auto button on, it seems to be working normal . when i press the off button, i have to reconnect hose #2, and remove hose #1 to disengage the axle .
Because of this i guess both VSV's are stuck open and pulling vacuum . would this be safe to say ? Dealer wants $250 for the pair of switches . A-lot of money on a guess.
Squealing noise and TOD check light on. natzilla Trooper | SLX | Bighorn | Wizard 0 06-10-2010 09:18 AM
'95 Trooper Brake and ABS Lights Boris Badenov Trooper | SLX | Bighorn | Wizard 4 01-30-2008 03:15 PM
2002 Alero - Trac, ABS, and SVS Weather Related oldmike Alero 1 12-02-2007 10:19 AM
ABS and AWD Disable 2002 Montana Versatrak kensell Montana/Montana SV6 0 02-09-2007 12:59 PM
2002 GT ABS and Traction Off Lights mikeswaggs Grand Prix 7 01-09-2007 02:26 PM
Tags
2002 , abs , tod , torrper
