Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 06-29-2012, 09:29 PM
mclaugj mclaugj is offline
no spark
i have a 1985 f-150 4.9 I have no spark out of the sparke plug wires I have eplaced the ignition coil the picup coil the ignition control modula the dis cap and rotor the coild wire and plugs wires still no spark ??
Old 11-16-2012, 07:44 AM
Max144 Max144 is offline
Re: no spark
Spark plug wires use to be made of wire, but they delivered out EMF and TV sets would pop and have spark lines on the display screen. They were changed with carbon fiber resistance cables to stop the disturbance. What you are finding is the cables cracking down enough that the spark is not being plugged properly and is moving along the outside rather of by the wire. It's time to change them.
[Spam signature file links removed by moderator]
Old 08-17-2013, 10:54 AM
ASE AMD ASE AMD is offline
Re: no spark
Bad connection/ wire. Check power and grounds to ign. Module. Or a bad a hall switch in distributor.
Old 01-10-2014, 11:07 AM
cwargo cwargo is offline
Re: no spark
I just went thru this with my 87 f150 5.0 I had to change the distributor after changeing relays and coil
Old 01-10-2014, 05:23 PM
rhandwor rhandwor is offline
Re: no spark
Their is a relay that supplies power to the computer system. On later models it was along side the fender. It is the same size as the green fuel pump relay. Also their a ground wire next to the computer check this is tight. Sometimes in the pass. side kick panel. I've found both of these problems on Ford's of this vintage. Newer models top left side of safety wall.
Hold your finger on top of the relay and you can feel them pulse when turning key.
no spark no spark NO SPARK!!!!!!!!!! javatrooper Cherokee 8 08-17-2013 11:02 AM
Spark, Fuel, But not fuel on spark plug? MoonChld454 Cutlass Series 5 05-02-2004 03:59 PM
No Spark at the Coil Pack/no spark to the plug wires crosscypher Off-Topic 13 02-04-2004 06:01 PM
Spark Plugs + Spark Plug wires ricodemus Engineering/ Technical 4 02-27-2002 12:23 PM
