Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-28-2012, 09:04 AM
khanguyen519 khanguyen519 is offline
Adjusting Parking Brake (E-Brake) pedal 6th gen Camry
I have a 2010 toyota camry that needs a parking brake adjustment. the car still stops with the transmission even if the parking brake pedal is pressed down. I changes the pads in the back and it seems to be a little better, but it's not as good as other Camry's i've been in. Can someone direct me to where to look as far as the adjustments go? and possibly how if it's not the usual method. thanks!
Old 06-30-2012, 02:58 PM
somick's Avatar
somick somick is offline
Re: Adjusting Parking Brake (E-Brake) pedal 6th gen Camry
As far as I know the parking brake has nothing to do with changing pads. Correct me if I am wrong. On my 2004 LE I have rear drums and the parking brake is mechanical. I have adjusted it couple of times during the life of the car. The process is fairly simple: remove center brake lever cover and tighten the nut.
For your generation the process might be different.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-30-2012, 04:22 PM
Good luck,
Sam
it may not entirely, but i notice the grip changing out to new pads in the rear. when pads are worn out, i suppose it takes a little more pushing of the pedal. i had a brake pedal, not one of the hand brake levers.
Old 07-07-2012, 01:40 AM
Joe W Joe W is offline
If you have rear disc brakes the e-brake is a drum assembly within the rotor on most Camry's that should require no adjustment under normal circumstances. If you have rear drum brakes the rear shoes require periodic adjustment to ensure proper e-brake performance.
Old 08-01-2012, 10:48 PM
The e-brake adjustments on a drum assembly are a periodical adjustment issue. If you have to pull up the e-brake more than 5 or 6 clicks the e-brake requires adjustment. The most effective option is to adjust the rear brake shoes instead of the cable. Raise the rear wheels and adjust the brakes to a slight resistance to turning the wheel after adjustment.
how to adjust parking brake theshadows Problem Diagnosis 3 03-27-2007 08:54 PM
97 SE adjusting Parking Brake kjellis Grand AM 1 06-17-2005 03:18 PM
adjusting parking brake rrroscoe General Discussions 1 09-28-2004 06:37 PM
Adjust parking brake? darkaccord Accord/TSX/Accord Hybrid 2 07-10-2003 08:30 PM
