Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 06-04-2003, 08:24 AM
rubberman rubberman is offline
Changing Plugs....
Has anyone changed plugs in their Montana? The front 3 plugs will be easy. The back 3 are impossible to get to. Just wondered how anyone access' the back 3?
Old 06-04-2003, 10:41 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
I do the rear plugs from underneath the van!
Old 06-04-2003, 10:54 PM
please tell me how you do that! isnt there too much stuff in the way?
Old 09-05-2004, 11:10 AM
Greg Knickle Greg Knickle is offline
spark plug change
That special tool that I found was called a ratchet strap tiedown. It worked like a champ.
Old 09-15-2004, 01:14 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Changing Plugs....
take the module/coil pack assembly loose(4 bolts) and then you can get to them relatively easily
Old 09-15-2004, 06:08 PM
worm6 worm6 is offline
i found that if the coil pack is off you dont have to move the motor. and save yourself some knuckle pain. the stock wires were still nasty to get off though.
Anyone change plugs on their Montana?... rubberman Montana/Montana SV6 26 07-07-2013 09:16 PM
plug wire tore when changing plug barry99astro M Bodies 3 05-24-2006 03:54 PM
How to change plugs in a 97 Venture? Squidworth Venture 3 02-03-2004 08:56 AM
How To Change Plugs? 1996 Passat GLX VR6 arawak420 '93 - '96 5 01-24-2004 11:30 PM
Rodeo 99 - changing plugs gavia111 Rodeo | Passport | MU 4 11-19-2003 08:56 PM
