Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 06-27-2012, 08:14 AM
uglydukwling uglydukwling is offline
stuck in park
I have a non-running '92 leBaron convertible (v-6, 4-spd auto) in my barn. When I tried to move it, I found that it wouldn't come out of park. I disconnected the shift cable at the transmission and found that the shaft for the shifter won't turn. There isn't enough room to get a pipe wrench on it or to tap it with a hammer to try to shake it loose, and it doesn't seem like a good idea to try to heat it with a torch.
I've been assuming that what's holding it is corrosion where the shaft goes into the casting, and all I can do is squirt penetrating oil on it every time I go by.
Any other suggestions? Is it possible that the problem isn't corrosion at all, and there's something internal that's keeping it from moving?
Stuck In Park & Stuck Key Dealer Says New Shifter Needed?? $300????????????? marathonman10 Focus | C Max 2 08-09-2006 10:08 AM
Stuck Parking Brake Dropped2KNeon Neon | Plymouth Neon 2 10-24-2004 07:14 PM
Stuck Parking Brake ganik17 Celica 5 08-06-2004 06:59 PM
98 Jetta stuck parking brake bradjetta '97 - '03 4 01-27-2004 08:12 AM
