Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-26-2012, 08:47 PM
Echos Myron Echos Myron is offline
Filler panel
I purchased an aftermarket front filler panel for my 1989 Caprice 9C1 and noticed two tabs beneath it (one on each end below the headlight area), and assumed they were designed to clip onto the top edge of the bumper. The cracked-to-pieces original panel did not have these.
I had my body shop paint and install the piece, but was very disappointed to find they had installed it without removing the bumper, therefore leaving the tabs above it and creating ugly gaps on either side. The shop claimed it was impossible to get the tabs under the bumper, but I don't believe that. I would assume that it can be properly positioned by removing the bumper. Anybody have experience with this? Thanks in advance.
Old 06-27-2012, 12:38 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Filler panel
You can remove the header panel, install your replacement filler, and then reinstall the header panel. When doing this, maneuver the header so these tabs notch under the bumper.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
HELP!! removing/installing bumper filler (front) youngwit88caprice Caprice 5 06-06-2009 07:06 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
1999 Jetta GL lens filler panel myrone '97 - '03 0 03-25-2008 11:38 AM
Tail Light Filler Panels??? EbenLudwig Cavalier 2 12-01-2006 01:23 PM
Tail Light Filler Panels? slowsofar Exterior | bodykits | Lighting 0 05-01-2002 07:35 PM
