Old 06-25-2012, 01:22 PM
Nobby Nobby is offline
A/C controller not working?
I notice the A/C wasn't working...drivers side never got cold like the passenger's side. I took the car in and they're telling me all A/C components work and none leak. Tells me my controller cannot set the range properly to close the driver's side door to be able to blow cold air like the passengers. He mention there is a bulletin out regarding the air duct/door warping over time resulting in this condition. Tells me the new model controller has a fix and that it cost $900.
Does this sound right?
I saw newer ones with the ECO button instead of A/C buttom like mine on Ebay going for $30-150.
99 intrigue with auto climate control
Old 06-25-2012, 03:29 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: A/C controller not working?
Nooby , go to top of this page and find the " search " function . Do an advanced search for " blend door problems " and many previous threads concerning this problem will show up . That may help you with your problem . Good luck !
" Sometimes I grow so tired "
Old 06-25-2012, 05:03 PM
brcidd's Avatar
brcidd brcidd is offline
Probably the cracked gear inside the driver's side actuator problem- just did one today-- does driver side actuator (above gas pedal) rotate as you go up and down on temp setting?-- if not then pull actuator off- open it up and see cracked gear-- I replace them with used actuator gears..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-28-2012, 09:08 AM
the heat temps work fine
this actuator, is found above the gas pedal? I take it I have to take off the fabric to get at it? What about the one behind the glove box? Can I get at it if I take out the glove box or does the whole dash have to come out?
I do notice there is no puddle of water under the car as there once was.
might have more then one problem here
But thanks inadvance
Old 06-28-2012, 10:38 AM
checked both actuators, even disassembled the passenger side. All seems to be working. Both doors only turn about a 1/4 turn so I assume this is correct.
one thing I must add
I've been noticing foam coming from the drivers side vent from time to time.
Wonder if it's leaking through the blend door since maybe the foam is ripping apart.
Old 06-28-2012, 11:17 AM
took temps from center console while sitting in cool garage and ran car for 5 minutes
right side 54
left side 65
seems high?
even after running car for 5 minutes there wasn't any water underneath and today is a ozone action day
I'm leaning on the compressor being bad
does anybody agree?
Old 06-28-2012, 01:52 PM
brcidd's Avatar
Compressor isn't bad -- low refrigerant is paramount......65% of time....Compressor can't work with near nothing in it!
'99 GMC Yukon
Old 07-19-2012, 04:24 PM
msg44 msg44 is offline
Most people with similar issues had what is already mentioned above.
#1. Low Refrigerant
#2 Driver side blend door actuator
You can completely disconnect the wiring and turn it on or off by hand to verify it is all the way on and then check temps.
I had to do both last summer!
ICV Idle Control Valve not working squawcrk Cavalier Problem Diagnosis 1 07-03-2010 02:04 PM
Cruise control not working, 2.5 automatic 98cirrus Sebring | Sebring Coupe | Convertible 3 06-26-2008 11:40 AM
vent control not working mz0dw4 C/K 4 11-25-2004 11:33 AM
98 G.Voyager Cruise Control not working Rev. John Caravan | Voyager 3 11-14-2003 02:27 PM
98 328i Cruise control not working 98328i 3 Series 3 08-07-2003 09:43 PM
