Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 06-23-2012, 11:36 PM
maddogg45 maddogg45 is offline
91 chrysler imperial
i saved this car from the scrap yard hopefully i did the right thing! when i got the car it was stuck in limp mode(only gears that work park neutral and 2nd), wasent drove for some time so all the codes gone. Anyways i changed the trans fuild and filter, and i should say when i checked it before buying the car it was overfilled i mean dip stick to the rim full. so i drained it and replaced the filter. now it still has the same problem and + it slips out of gear some times into neutral now(in both reverse and drive it slips outta gear). so im stuck on what to do if i spend anymore money on it and can't fix without putting it in the shop ill lose my money. i have $300 in it all the power windows lights radio all everything works motor runs good needs a tune-up but other than tran problems its an ok car was going to resell it and make a few hundred. i was feeling like it was an electric issue at the start but really at a loss now. i still think i could scrap the car and get my money back and run! any help would be greatly appreciated.
93 Chrysler Imperial with a different but broken Master Cylinder ERPM General Discussion 0 08-04-2009 09:07 AM
F.S. Chrysler Imperial must go asap butand50 General Discussion 0 10-03-2005 08:24 PM
F.S. Chrysler Imperial must go asap butand50 General Discussion 0 10-03-2005 07:51 PM
1967 Chrysler imperial Rbraczyk General Discussion 1 06-27-2004 01:57 PM
Chrysler Imperial delamothe General Discussion 0 11-26-2002 09:57 PM
