Go Back   Automotive Forums Car Chat > MG > MGB
Old 06-23-2012, 09:46 PM
marlinswimmer marlinswimmer is offline
Momentary loss of power (electrical) 80MGB
My 1980 MGB (USA) has had this problem for a couple of years and I have not been able to solve it. Going down the road it will loss electrical power for a moment or 2 then start back up. I have had it backfire (blew out a muffler). It happens at low speeds, high speed, maybe on a bump on a smooth road. When it happens tach also goes dead. I found some information that if the igntion light was on, probably would be bad ignition switch and if the ignition light was not on then probably bad at the igntion relay. The igntion light does not come on when it dies. However, I checked and replace the ignition switch anyway since where the wires went in were a little loose. Took the old one apart and it was in pretty bad shape inside. Still having problem. Replaced the ignition relay and checked all the connections. Still having the problem. Seems to be happening more frequently. Went for about a 4 more drive around the neighborhood and it happened 5 times. Loses electrical power, engine dies, no tach, then starts back up.
I'm pulling my hair out.
Old 06-26-2012, 09:02 PM
Re: Momentary loss of power (electrical) 80MGB
Hopefully, I have solved the problem. The HT going into the coil was not fully engaged. The boot was fully on the tower, but the terminal was not seated fully down into the female connection. The boot was holding it metal to metal but apparently the wire was gradually working back through the boot which is why it was getting worse. I pulled the boot back, fully seated the terminal then pulled the boot back down the wire onto the tower. I've gone for 2 drives (about 20 and 10 miles) with noth loss problem. Hopefully, fingures crossed, this puts this one down.
Old 10-11-2012, 08:40 PM
Well I have not solved the problem. It has come back. Went for a drive and lost power dead and right back 3 times in a 2 mile drive.
2005 Grand Prix SE. poor fuel economy and power loss rogerwc Grand Prix 4 09-14-2011 08:33 PM
2003 Sienna Gummed Engine, Power Loss, Clicking Nebeno Sienna 3 07-17-2010 07:05 PM
power steering problem in the rain eu0688 Impala | Impala SS 2 12-13-2009 11:23 PM
Power Loss in an '89 4Runner toyotatech89 4Runner/GX470 6 08-07-2009 01:23 PM
Momentary loss of current during start doughanson56 Expedition 0 11-20-2005 08:56 AM
