Old 06-23-2012, 11:37 AM
Redlegger Redlegger is offline
Install Overhead Trip Console
I have a 2005 Grand Caravan and a 2002 Grand Caravan Sport. My 2002 has just been totaled and before they come get it I am swapping out some accessories. I was going to take the overhead console out of my Sport and swap it for the basic one in my 2005. Is it as simple as disconnecting some wires and does anyone know how these are removed. I don't see any visible screws. Thanks.
Old 07-03-2012, 08:56 PM
Alphabravo Alphabravo is offline
Re: Install Overhead Trip Console
If your 2005 is the same as the 2003, open the sunglass compartment and you'll see a black phillips screw.
Be sure to take the wiring harness off your donor vehicle. It runs down to a connector at the base of the door pillar one the passenger side. It goes to all the overhead lights, too.
I did the same thing in one of my vans. Not hard to do. good luck.
P.S. Your outside temp readout won't work. Unless you also grab the temp sensor and the harness that goes with it. I never got that far on mine.
Last edited by Alphabravo; 07-03-2012 at 09:06 PM. Reason: Added info about outside air temp
Old 07-04-2012, 10:39 AM
I have been chicken to pull he console out of the one without a screw as well as the one with the screw. Do I just pull it down ? Can I break it if not careful ? I am assuming I will have an area of missing overhead liner. Will I need to cut out the overhead liner in the one I am installing ?
Old 07-04-2012, 09:08 PM
Ok. so the one without the screw is the one without the trip computer and all the other stuff, right? Sorry I can't remember how I got that one off. I think I just pried with my fingers. Not too hard to tear the headliner, though. Try pulling down slightly and looking for a tab to push in or something. Sorry, that's one thing I can't remember how I did.
Yes, you will have to cut the headliner. Since you're scrapping the donor vehicle, I would cut that whole section out and use it as a template. The headliner cuts surprisingly easy with a utility knife, just use a new blade. You can even make some cuts on the donor vehicle for practice. It's easier than cutting through carboard.
Also, take from the donor vehicle the black plastic bracket that the overhead console mounts on. You'll need it in the other van.
It's really not hard at all, but you'll ba a couple hours doing it.
Old 07-04-2012, 09:28 PM
On second thought, I vaguely remember pulling out the lights. See if there are screws under there. If not, just pry gently down and peek in there for a tab to push.
Good luck.
2003 Impala overhead homelink console install dcranb Impala | Impala SS 28 12-10-2016 04:00 AM
Installing Overhead console Ragtop68 Blazer 4 08-07-2005 11:19 PM
Installing Overhead Console? mccain134 Envoy 2 03-26-2005 05:08 PM
installing overhead console theguyfromnj C/K 0 08-01-2004 09:35 AM
install overhead console in Windstar? autoforums Windstar 1 07-21-2004 12:57 PM
