Old 06-20-2012, 06:58 PM
cdzenga cdzenga is offline
96 Ford F-150 a/c heater blower fuse
Yes I was wondering if someone could tell me why my fuse for the a/c and heater blower keeps melting!
Old 06-21-2012, 01:08 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 96 Ford F-150 a/c heater blower fuse
Sounds like you have a short somewhere in that particular circuit ! Your ac / heater fan may have locked up and when you try to turn it on , it blows the fuse ? Does the fuse blow instantly or will the fan run for a short time ? Do you get any air movement out of the fan before the fuse blows ? Can you give us more info ?
" Sometimes I grow so tired "
Old 06-21-2012, 05:50 AM
The blower works fine! It will work on low,mid and high! It don't blow the fuse either! Its like it gets so hot it is melting the fuse!
Old 06-21-2012, 09:31 AM
oldblu65's Avatar
The fuse is an intentional " weak link " in each circuit . So whether it is " blowing " or " melting " shows that particular circuit is " pulling " too much current therefore causing the fuse to destruct ! When you say the fuse " is melting " - do you mean that literally ? Are you saying the entire fuse ( body and all ) is melting or just the visible small loop of metal wiring ?
Old 06-21-2012, 05:11 PM
The actual plastic body of the fuse!
Old 06-21-2012, 05:52 PM
oldblu65's Avatar
When this happens , does the metal loop of the fuse melt as well or is it basically still intact ? Is the fuse panel itself damaged or just the fuse ?
Old 07-02-2012, 07:57 AM
Only the fuse casing itself is melting! The metal components are staying intact! I did change the melted fuse and now every fuse i put in it blows and it burnt the fuse slot where my blower fuse goes! So now my a/c will come on but blower will not not blow due to fuses blowing now!
Old 07-02-2012, 09:40 AM
oldblu65's Avatar
It sounds like you may have a short within the fuse box itself ! If the metal loop within the fuse is not blowing but the outer plastic fuse body is melting , it indicates to me that the fuse box itself is getting very hot ( dangerously hot ) . If it's getting that hot , then a fire is a possibility and you should get a professional involved to find the source ( cause ) of the problem . I'm sending you a PM with another suggestion that might help .
