Go Back   Automotive Forums Car Chat > Chrysler > Pacifica
Old 06-19-2012, 09:46 PM
timrantz2 timrantz2 is offline
o2 downstream problem
I had a surging problem when cold at 25-35 mph. replaced both o2 sensors with bosch. Problem went away. Now have check engine light. code says downstream o2. replaced o2 downstream with another bosch, same problem. I think the stock o2 was a denso. any suggestions? Thank you.
Old 06-20-2012, 10:55 AM
danielsatur danielsatur is offline
Re: o2 downstream problem
Incoming Air -> MAF sensor -> Engine -> H02 sensor for a feedback signal.
Did you clean the MAF sensor with CRC MAF sensor cleaner?
Old 06-20-2012, 11:25 AM
Thank you!
I will clean it.
Tim
Old 06-20-2012, 09:16 PM
I cleaned the MAF 35k ago. the car has 83k. After I put a new filter in, I will let you know if the light goes out. Does the orientation of the MAF matter?
Old 06-21-2012, 08:25 AM
autojoe autojoe is offline
cleaning maf might remedy a lean code if the maf element was dirty or contaminated but a 02 code.........what code are you getting?what size engine?
Old 06-22-2012, 12:27 PM
I cleaned the MAF and replaced the air filter for the engine. I haven't driven it, so I will let you know if the light goes out. I did not write down the failure code. When I go back to the mechanic I will ask him for it. I do have a leak at the throttle body. The engine size, 3.5
Thank you.
Tim
Old 06-22-2012, 08:16 PM
you will need to replace throttle body gasket....this will cause a lean condition
Problems with my 88 Caprice Tranny.. My Fix did not solve the problem. kevn83 Caprice 5 10-03-2007 09:54 AM
99 Yukon - Steering Problem [not the common vibration problem] mtwhite Yukon 6 08-23-2007 03:39 PM
Electrical problem or mechanical problem? Godofwarmike 1st Gen 95-99 4 04-20-2007 07:35 PM
engine problems. always engine problems. alwaysproblems Fiero 2 04-09-2007 01:56 PM
