Old 06-19-2012, 12:02 AM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Tamiya Mercedes Sauber C9
I got this kit a couple of months ago and after watching the 24 hours of Le Mans this weekend I got the urge to dive in! I haven't built in some time so I wanted something easy and quick to build but interesting enough to keep my interest. This kit was bought used (for $25 with a Scale Motorsports PE set AND carbon fiber decal set!) so after inventorying the parts I started cleaning them up one by one. 90% of the parts were loose but needed the sprue tabs removed and attention, I'm just about done with that. Some parts are getting PE attached as I go and sub-assemblies set aside. I needed to do something interesting so I opened the door and I'm adding the ridge that surrounds the opening. My goal is to finish this within one month, much left to go, stay tuned!
My AF Classic Model Car Gallery
Old 06-19-2012, 12:57 AM
RonCla's Avatar
RonCla RonCla is offline
Re: Tamiya Mercedes Sauber C9
I'll keep an eye on your build. One of Tamiyas' classic kits. I've had the same kit sitting in my stash forever.
Old 06-19-2012, 01:40 AM
phillipshaw phillipshaw is offline
Good start! It seem's great!
“In three words I can sum up everything I've learned about life: it goes on.”
― Robert Frost
Old 07-15-2012, 05:18 PM
Murco's Avatar
Maximum Car Guy
One month... HA! Didn't expect my life to become so busy but it did and the model progress has been slower than expected.
Let me start this update with a warning, the Scale Motorsports PE is incredibly hard to bend! A little overly complex as well. The rotor detail pieces should have been made with thicker material (like nickel) and if done in a relief could have offered more easily attained detail. Ok, enough griping!
I completed the body modifications and got it painted, the front to rear shell attachment positions got tweaked for better fit as well...
The door got it's inner surround (solder) and will be sanded to shape soon before being covered in carbon-fiber...
Here is where I went a little stupid... I decided the intake horns/fuel rails were not good enough as they sit right up top and are so visible. So I removed the kit peices and started with new horns, the fuel rails are there awaiting to be joined, and I'll make the regulators tonight. I also added the cooling lines from the valve covers and shaped them as the originals...
With most of the larger details complete I now will add some of the smaller details for tubing, reference lines, wiring, and plumbing...
More to come!
Old 07-15-2012, 11:49 PM
Murco's Avatar
Maximum Car Guy
Gettting into some details, most everyone here knows how to wire distributors and such so I'll stick to other stuff...
I made cooling lines from brass, painted them silver, then added hose connectors and holds from heat-shrink tubing, and used PE tree material to loop around the holders to make effective brackets...
This works well for any hose and clamp set-up, I usually use solder for the hoses before adding the heat-shrink.
Old 07-16-2012, 12:01 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
wow. shaping up to be a well-detailed kit! me likey
olly olly oxen free
Old 07-16-2012, 04:00 AM
rgriffs rgriffs is offline
nice start, i have one in my stash too.
Old 07-17-2012, 01:05 AM
Murco's Avatar
Maximum Car Guy
Trial fitting the components made last night, including the new fuel rails with regulators. Painted the engine and transaxle with metallizers, detail painting with fine-tip paint markers...
Don't judge it yet, a lot of fine-tuning to be done!
Old 07-18-2012, 03:51 AM
Shunter's Avatar
Shunter Shunter is offline
Love this car so looking forward to your build. Nice start and i love your idea for the pipes and the clamps, great thinking.
Cheers
Shayne
http://motorsportmodeller.blogspot.com.au/
Old 07-18-2012, 07:14 PM
Murco's Avatar
Maximum Car Guy
Thanks, I appreciate that! But after looking at the pics (and test fitting revealed an ill-fitting line) it just looks too out-of-scale to use the heat shrink on this small a line. This method works well on a 2" radiator hose but the wall thickness is too great for this size line and it looks like roll-bar padding attached to the tube!
After painting a new hard-line I will use electrical tape and BMF to replicate the hose portions. I'll post the results tonight!
