Old 06-18-2012, 05:37 PM
1534dover 1534dover is offline
Engine Hiccop
The last week or so my 1996 LaSabre has kind of made a hiccup, usually on accelerating, I think. It doesn't happen with any kind of regularity, about once on a ten mile trip. I don't think I can make it happen. Is this an engine or transmission problem? Something else?
Old 06-18-2012, 09:27 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: Engine Hiccop
If it's light acceleration and usually in 4th where the ignition system is under the greatest load..., I'd think about replacement OEM quality wires for the spark plugs and new spark plugs, the recommended AC Delco model. That is if the wires have more than 40K on them and the plugs the same or the plugs are another brand.
The hiccup reminds me of a miss where my plug would occasionally short to the metal guard around the snapon portion of the wire at the plug.
Old 06-20-2012, 12:48 AM
happydog500 happydog500 is offline
Re: Engine Hiccop
I agree with imidazol97.
I had the same thing and it turned out to be a broken spark plug. Wish I would of checked it before since I drove it like that for a year.
You might want to have it scanned, could be a problem with the air flow sensor or something like that.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 06-20-2012, 12:52 AM
Re: Engine Hiccop
I had the engine codes read and they showed a problem with the air flow sensor. The mechanic fixed it. I could probably use the new wires and plugs, though.
86 buick lesabre estate wagon with 70's olds 455 big block engine in need of help kcbuechler LeSabre 29 06-26-2012 09:21 AM
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 09:42 PM
Engine Swap 1996 4.3 S10 Engine Going In A 1991 Blazer What Changes In Exchange in2classx Problem Diagnosis 1 08-27-2008 09:05 AM
Cold engine = stalls Hot engine = rough idle Dave01234 '97 - '03 2 02-19-2008 11:35 PM
